What rear end
Old 04-15-2011, 09:52 AM
Farmboypowerstroke's Avatar
Farmboypowerstroke
Farmboypowerstroke is offline
What rear end
What rear end would be in a 1993 dually? I don't know if its f250 or 350 two or four wheel drive. They would all be the same right?
Old 04-15-2011, 11:20 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,156 Likes on 914 Posts
It should be a Sterling 10.25". I am not sure if the dually versus SRW are the same?
Old 04-15-2011, 12:48 PM
nstueve's Avatar
nstueve
nstueve is offline
DRW's are Dana 80's I am pretty sure... Dana's have a 10 bolt rear diff cover and Sterlings have a 12 bolt.
Get the 2 digit numeric code off the door sticker under "Axle" and look it up on the chart. Then you'll know the maker and gear ratio.
https://www.ford-trucks.com/article/...de_Chart_.html
Old 04-18-2011, 08:34 PM
Phy's Avatar
Phy
Phy is offline
Both my 93 F250 SRW and my 93 F350 Dually (cab & chassis) have Sterling 10.25s...
Joshiggity
07-28-2010 07:06 AM
kentruckf100
04-06-2010 07:44 PM
69-f100
01-30-2010 12:47 PM
jw miller
07-06-2009 10:37 AM
A92Van
Aerostar
12-14-2003 04:40 PM
Quick Reply: What rear end
