95 351W Air Pump Bypass Question - Ford Truck Enthusiasts Forums
Old 04-08-2011, 12:52 PM
CS45's Avatar
CS45 CS45 is offline
CS45 is starting off with a positive reputation.
Good Day to All
My airpump seized up and I have it off the motor. I have read threads about bypassing the pump completely (requiring a new smaller belt).
The truck already has Ford Racing shorty headers, custom Y pipe to high flow cat and flowmaster exhaust and the air pump plumbing is gone. I have run this set up for almost a year with no codes / CEL.
What I'd like to know is:
1. For anyone that has done this mod can you tell me what size belt you've used. The present belt is 102".
2. I've read in another forum that doing this mod will put more strain on the altenator pulley, but that doesn't make sense to me.
I'm planning on using the idler pulley and auto belt tensioner as in the original set up, just take out the air pump from the equation.
Thanks for your time and assistance.
CS45
Old 04-08-2011, 04:41 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Old 04-09-2011, 02:42 PM
CS45's Avatar
Thank you for that link. I will have to try the different methods of routing the belt.
I did try just routing the belt with eliminating the air pump but it seems that the auto tensioner doesn't work that way. I came up with a 94.5" belt. I am waiting for my new rad to be delivered so I can't run the truck up before then.
CS45
Old 04-11-2011, 08:48 PM
CS45's Avatar
Update for those who care.
Turns out eliminating the air pump (or smog pump) on the 351W isn't as easy as you would think. I ended up having to purchase a eliminator pulley from Jegs. I am waiting to see if I can use the original belt or have to down size. According to Jegs it's a straight bolt on replacement but I'm learning that seeing is believing with my Ford.
On another note I noticed that the seal on my fan clutch was leaking and there was hardly any resistance to it, compared to the replacement I got today. Another 60 bucks gone.
Still waiting for my brass/copper rad to be delivered and installed.
CS45
Old 04-12-2011, 11:36 AM
White Max's Avatar
White Max White Max is offline
White Max has a good reputation on FTE.White Max has a good reputation on FTE.
Quote:
If your FEAD has the upper idler with the tensioner located just below the alternator, you can do without the eliminator pulley by using a slightly different belt routing. The routing of the belt is as follows: from the crank pulley around the water pump pulley, to the ps pump, to the ac compressor, under the tensioner (not the idler), to the alternator, then back to the crank pulley. You won't use the upper idler pulley in this configuration. If that is hazy, I can get a picture for you. On a 5.0L, this routing uses a 94.0" belt. A 5.8L will use a slightly longer belt, but without having one here to measure, I don't know the correct length.
If your FEAD has the upper tensioner, you'd be able to keep the factory routing while eliminating the air pump.
Old 04-12-2011, 11:59 AM
cpettymore7777 cpettymore7777 is offline
cpettymore7777 is starting off with a positive reputation.
i would like to see a pic of that. i was planning on doing a bypass
Old 04-12-2011, 08:01 PM
White Max's Avatar
I didn't realize how difficult it would be to get a clear pic with the huge factory fan shroud in the way. Hopefully this helps.
Old 04-12-2011, 08:14 PM
KevinGnWV's Avatar
KevinGnWV KevinGnWV is offline
The village idiot.
KevinGnWV has a good reputation on FTE.KevinGnWV has a good reputation on FTE.KevinGnWV has a good reputation on FTE.
Quote:
That was exactly what I needed to know. Thanks a ton! Tried to rep you but I still can't, sorry.
Old 04-13-2011, 10:01 AM
White Max's Avatar
No problem. Glad to help.
Old 04-17-2011, 09:44 PM
CS45's Avatar
I ended up going with the replacement idler from Jegs. Belt is routed the same and the belt is the original 102" long.
The biggest difference I noticed was how much more quiet this set up is. Thanks again for those who chimed in to help.
On to the next problem. Coolant leak at oil filter adapter/oil cooler thing. It's the next part to be recycled.
CS45
Old 10-07-2012, 10:40 AM
Kevin Roth Kevin Roth is offline
Kevin Roth is starting off with a positive reputation.
[QUOTE=White Max;10213486]I didn't realize how difficult it would be to get a clear pic with the huge factory fan shroud in the way. Hopefully this helps.
White Max has the solution. See the pictures ealier in this thread. This worked for me on a '96 E-350 w/ 5.8 351W. Tensioner mounted on the side. Belt length (after some experimentation) turned out to be 97.5". Some users might have "belt flap" issues at high rpm. This truck is a stock, low rpm hauler for me. Save yourself the $60 for the eliminator bracket if you can. Thanks for "The Solution" to the smog pump issue White Max.
Old 10-30-2012, 04:04 AM
cris f peņaloza cris f peņaloza is offline
cris f peņaloza is starting off with a positive reputation.
new answer
using the stock belt of bronco 5.0 xl 1995
removing the air pump pulley
View image: NUEVA POSICION DE LA BANDA
Old 10-30-2012, 08:31 AM
White Max's Avatar
Old 10-30-2012, 03:35 PM
2002 F350V10 2002 F350V10 is offline
2002 F350V10 is gaining momentum as a positive member of FTE.
I just removed the thermactor on a 92 F150 with the 5.0 and I used an 88.8 length belt made by continental routed in the factory way.
Old 10-30-2012, 03:54 PM
White Max's Avatar
Quote:
IIRC, a '92 has the upper tensioner FEAD arrangement, doesn't it? If so, you're golden.
A/C Bypass Pulley or Different Belt ??? BadDogKuzz 1999 - 2003 7.3L Power Stroke Diesel 13 03-03-2016 08:47 PM
1996 smog pump locked up ricky1 1987 - 1996 F150 & Larger F-Series Trucks 3 03-12-2013 07:51 AM
Anyone have a part number or belt length to bypass the smog pump on an 87-97 351 ? baddad457 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 06-02-2012 02:56 PM
smog pump removal info luconn3 1987 - 1996 F150 & Larger F-Series Trucks 1 02-05-2012 03:15 PM
Belt Shredded (Air Pump Pulley) trotsky13 1987 - 1996 F150 & Larger F-Series Trucks 28 11-29-2009 08:04 PM
Tags
1977, 1995, 351, 58l, 95, air, belt, f150, ford, fuel, pictures, pump, run, size, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
