95 351W Air Pump Bypass Question - Page 2 - Ford Truck Enthusiasts Forums
Old 10-30-2012, 09:04 PM
2002 F350V10 2002 F350V10 is offline
2002 F350V10 is gaining momentum as a positive member of FTE.
yes it does
Old 11-25-2013, 01:55 PM
jetedwards jetedwards is offline
jetedwards is starting off with a positive reputation.
i just had this happen to me. and removed wheel from the air pump;couldnt believe the bolts didnt strip cuz they were so small, reroute belt like whites pic except from cs to alternator to bottom of tensioner to top of pulley above it then to power steering.......perfect used stock belt only thing!!!!!!!!!!!!!!!!!! you need to move the radiator hose!!!!!!!!thebelt will grind a hole in it i undid to intake hose and ran it under the radiator hose. plenty of clearance. hope this helps somebody takes about 5 min or less and its free
Old 06-30-2014, 11:36 PM
carlislefordf250's Avatar
carlislefordf250 carlislefordf250 is offline
carlislefordf250 is starting off with a positive reputation.
Quote:
Originally Posted by White Max View Post
I didn't realize how difficult it would be to get a clear pic with the huge factory fan shroud in the way. Hopefully this helps.
will this cause your belt to squeal when you start up because more contact on alternator?
Old 07-01-2014, 01:09 PM
Nothing Special's Avatar
Nothing Special Nothing Special is offline
Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.
No. More contact gives the belt a better grip so it will be less likely to squeal.
Old 01-07-2015, 04:42 PM
wendal wendal is offline
wendal is starting off with a positive reputation.
I have a 1997 F250 with the 5.8. I am considering deleting the smog pump.
I like the reroute method. Can anyone tell me what length of belt to buy?
Any other advice is ok too.
thanks again
Old 11-19-2016, 02:59 PM
plainbroke plainbroke is offline
plainbroke is starting off with a positive reputation.
"The Solution" to the smog pump issue thanks to White Max
"The Solution" to the smog pump issue thanks to White Max. He used a 97.5" belt with some belt deflection.
I just did this Smog Pump/Air Pump delete this week on my 95 EB 5.8L AC/Alt/PS/WP/crank pulley.
I used a 97 1/8" belt from O'riellys, I ran the belt under tensioner like the pictures just as tight as
original belt was and I get no more belt deflection than I did with the factory one.
Old 11-19-2016, 03:02 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Great photo and feedback on a very common question.
welcome to FTE!
A/C Bypass Pulley or Different Belt ??? BadDogKuzz 1999 - 2003 7.3L Power Stroke Diesel 13 03-03-2016 08:47 PM
Smog pump delete belt length? 351/5.8 UNTAMND 1987 - 1996 F150 & Larger F-Series Trucks 7 02-09-2016 08:06 PM
1992 F-150 5.8 Air Pump Question TX92F150 1987 - 1996 F150 & Larger F-Series Trucks 7 09-05-2015 06:30 AM
86 300cid seized air pump options Rustlin' 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 08-24-2015 09:11 PM
e-350 van air pump? silencergroup 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 4 05-28-2008 02:12 PM
Tags
1977, 1995, 351, 58l, 95, air, belt, f150, ford, fuel, pictures, pump, run, size, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
