window rolls down, but not back up - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 04-08-2011, 12:30 PM
m.tuba m.tuba is offline
m.tuba is starting off with a positive reputation.
hello, long time listener, first time caller.
I have a 03 expediton, the window on the passenger side will roll down but will not roll back up, we replaced the motor but that wasn't it(realize now this was a hasty decison). We then tried taking the switch from the drivers rear door and swaped it with the passenger front, that didn't fix the problem. The switch from the passenger front works on the driver rear window though.
Any ideas on what the culprit is? btw i searched the tsb's and through 10 pages of the search, no luck
thanks in advance!
mike
Old 04-08-2011, 03:15 PM
jeebie's Avatar
jeebie jeebie is offline
jeebie is starting off with a positive reputation.
Our 06 does the same thing although it is hit and miss right now on whether it will go back up. I just use the driver side if it won't go up. My hubby thought it was the switch but maybe not.
Old 04-08-2011, 03:55 PM
Z06PSI's Avatar
Z06PSI Z06PSI is offline
Z06PSI is starting off with a positive reputation.
What about the regulator? or is it combined with the motor? I am unsure.
Old 04-08-2011, 04:26 PM
RedHorse1 RedHorse1 is offline
RedHorse1 is starting off with a positive reputation.
The regulator and motor are separate pieces. I've had to replace both front regulators on my '03. My symptoms sound a little different to yours tho. Up and down were both slow and I could hear a grinding sound. Eventually it wouldn't go up at all without help. Not a big job to replace. Search for "yardbird", he posted an excellent how-to with pics on the regulator replacement. It's several years old now but you should be able to find it.
Old 04-08-2011, 05:31 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
Originally Posted by m.tuba View Post
we replaced the motor but that wasn't it(realize now this was a hasty decision).
If the motor works to run the windows down, then it's not bad...right?
Replace the master switch in the driver's door. The power and control wiring first runs through it, then it goes on to the other door switches.
You might try beating on the front passenger switch in the driver's door to see if you can make the window go up. This would at least confirm the switch is the problem.
Old 04-08-2011, 06:50 PM
Yeah, thanks alloro, my buddy bought the motor before he go me involved.
we cleaned the contacts in the drivers side door switch, it works now, you just have to push hard and it'll go up,
Old 04-09-2011, 08:50 PM
I remember a post on how-to clean the window switches.
http://www.ford-trucks.com/forums/87...ow-switch.html
Check this link out.
Old 04-10-2011, 10:21 PM
cdherman cdherman is offline
cdherman is starting off with a positive reputation.
To clarify: It goes down with power, and then?
a) no motor at all going up?
b) motor groans to a stop?
c) creaking, squeaking occurs and it stops?
a) bad switch, somewhere
b) just like mine, tracks need to be cleaned and lubed, silicone the rubber parts. Ford did not get this one just right. Many others have same problem..
c) possible b), but also could regulator or cables messed up.
If its any consolation, I too replaced the motor, only to find that it was the same afterwards....
Old 04-11-2011, 12:08 AM
Do you think that maybe next time you might try and read the thread before posting? The problem was solved. It turned out to be the driver's master switch.
Old 04-06-2012, 05:40 PM
ljackson911 ljackson911 is offline
ljackson911 is starting off with a positive reputation.
Possible Alternate problem to look for.
I know this user has solved the problem, but I wanted to add my 2 cents, as I used this thread to help solve the problem. I went step by step thru this thread to fix RR window not rolling up. Found that it was a dirty contact in the drivers master switch. Put it all together only to find that the window still wouldn't roll up using the RR switch. That's when I noticed that the small plastic post that actuates 'up' had literally melted off. Electrical works fine. Anyone have any insight into what causes this? ('01 SuperCrew)
Old 04-07-2012, 06:15 PM
I have an 05 super duty that also had the same problem with the switch as your super crew, and needed the switch replaced. I think that the switch gets hot from the bad connection and melts the internals. That's my opinion
Old 04-09-2012, 01:05 PM
@m.tuba... Did you experiment at all with cleaning the contacts before you replaced the switch? Wondering if it's worth the effort.
Old 04-09-2012, 06:29 PM
No, on the super duty, when I disassembled the switch it was too far gone and just replaced the switch
Old 07-21-2012, 12:11 PM
jampen jampen is offline
jampen is starting off with a positive reputation.
I fixed this problem
2004 F250 Crew Cab SuperDuty, 6.0 Diesel
Passenger side window would roll down but not back up and there were no sounds coming from motor or door when I tried to roll it back up.
$123 replacement switch panel from local parts depot. Popped the old one out, unplugged 4 power plugs from bottom of units, popped new one in.
Everything worked fine. Easy fix except for the cost of the part.
This is what I bought
http://www.switchdoctor.net/ford-win...m-4-door-.html
Old 06-13-2015, 09:54 PM
derriwepperly derriwepperly is offline
derriwepperly is starting off with a positive reputation.
Smile 2001 Expedition driver power window won't roll back up
I read someone's post to hold down power button while slamming door hard, and it worked!!! Of course, make sure the car is running at the time.
Passenger rear power window will not roll down TruckingBill 1999 to 2016 Super Duty 10 02-08-2017 11:44 AM
Has anyone ever had this problem? steager_94 2004 - 2008 F150 3 08-02-2016 11:50 PM
Power windows problem. ugh3012 1999 to 2016 Super Duty 1 07-04-2016 09:54 AM
04 sport trac windows not working ProudFordMan Explorer, Sport Trac, Mountaineer & Aviator 6 06-11-2015 07:33 AM
passenger side window won't roll up. remj93 1999 to 2016 Super Duty 0 03-16-2015 08:37 PM
Tags
2002, back, explorer, fine, flex, ford, power, pwer, rear, roll, rolls, sport, trac, window, wont, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
