Tractor turbo swap
Tractor turbo swap
Just thought I would make a new thread instead of fill up the BS thread with 15 pictures. Old turbo was definitely tired at nearly 7600 hours, worked hard many of those. New turbo really cleans up the smoke good. Backed out the fuel screw after the install and it smokes less than before. Only purchases to complete the install were: turbo, manifold, exhaust sleeve, manifold to turbo adapter. Not a truck but it is a Ford engine, one I wouldn't mind having in a truck either.
The candidate, Ford 9600, round screen on the front is a self cleaning radiator shroud from a combine.
Underhood view before
Old turbo and connections
Manifold, old to new. Picked a divided manifold from newer tractor.
Compressor comparison
Same picture as in the BS thread
Exhaust sleeve plate, bored on lathe to accept the larger exhaust sleeve.
Exhaust sleeve tested for fit
Manifold
T3 to T4 adapter
Turbo and connections
Another view
intake connections
Hood support back in place with heat shield
Manifold
T3 to T4 adapter
Another view
intake connections
Well the old manifold was only used from the 8000-9600, anything newer than that has the new manifold style that I swapped in. Yeah we could probably upgrade that filter too, doesn't get too much hours or oil changes though, few too many tractors around. Since it was mentioned, I did some looking with the shortline product dealers for us and found that adapter. It can be had for sub-$100. If you have a local A&I products dealer you can get A-DKPN6882A, or from All State Ag Parts 115060.
avf100
06-13-2017 11:49 AM
TXstroker01
25
07-29-2010 10:56 AM
