240 connecting rods - Ford Truck Enthusiasts Forums
240 connecting rods
Old 04-07-2011, 11:47 PM
troy's66customcab troy's66customcab is offline
troy's66customcab is starting off with a positive reputation.
240 connecting rods
OK i bought a set of refurbished connecting rods for my 66 240. should i have the rods balanced since I'm sure they didn't come from the same engine or does this matter?
Old 04-08-2011, 12:12 AM
billt28's Avatar
billt28 billt28 is offline
billt28 is gaining momentum as a positive member of FTE.billt28 is gaining momentum as a positive member of FTE.
I would recommend taking them to a machine shop and have them reconditioned.
Old 04-08-2011, 01:14 AM
F-250 restorer's Avatar
F-250 restorer F-250 restorer is offline
F-250 restorer has a good reputation on FTE.F-250 restorer has a good reputation on FTE.F-250 restorer has a good reputation on FTE.
If you're going to keep it, I'd have it balanced. Take the pistons too.
Old 03-31-2012, 03:38 PM
seattle smitty seattle smitty is offline
seattle smitty is starting off with a positive reputation.
Yup! You don't want to put an engine together and find that the rearview mirror shivers in certain rpm ranges. A slight imbalance at 4500rpm can amount to hundreds of pound of force, beating your bearings, ripping up your motor mounts, cracking various things. An inline six can be made to run very smooth, if you're willing to spend the money and//or do the work. Fortunately, Ford Big Six crankshafts have been found to generally be rather well-balanced from the factory, so you could save money there. But you definately want to get your rods balanced end-for-end, and the pistons, and most definately the flywheel, if you have it reground. I went the cheap route (no balancing) a few times when I was young, but the third one shivered the mirror, and fasteners wanted to back out. Now I get complete balancing jobs done (incl. Big Six cranks); expensive, but worth it to me.
Old 03-31-2012, 07:09 PM
Harte3 Harte3 is offline
Harte3 is gaining momentum as a positive member of FTE.Harte3 is gaining momentum as a positive member of FTE.
What Herr Schmidt said X2.
piston compression distance? troy's66customcab Ford Inline Six, 200, 250, 4.9L / 300 1 03-19-2011 01:27 AM
replacement cab mounts troy's66customcab 1961 - 1966 F-100 & Larger F-Series Trucks 9 01-08-2011 02:33 PM
rods for the 240 L6 and the 300 L6 jnj4fords Ford Inline Six, 200, 250, 4.9L / 300 3 10-06-2005 08:32 AM
Connecting Rod Lengths jnj4fords 1967 - 1972 F-100 & Larger F-Series Trucks 1 10-05-2005 11:13 PM
390 connecting rods jazzy66 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 09-21-2004 10:48 AM
Tags
240, 300, connecting, connector, dtraight, ford, forged, fprd, i6, inline, raptor, rod, rods
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
