Went to O'Reillys and found out some not so good things.... - Ford Truck Enthusiasts Forums
Old 04-07-2011, 09:51 PM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
Ok fellars......Here we go again.....
I took the truck to O'Reillys....Turns out I have a slight oil drip, and either a intake gasket or a injector O-Ring leaking, or both....The intake gasket , and a new set of injector o rings are roughly $25....I figure why not rePlace both at one time.....Now the oil drip has to be either: Oil pan gasket, or rear main seal....Both of which I am sure are major PITA's....If it's the rear main seal, I'll just hold off till I get the $$$$ to do some beadwork and a camshaft....Just posting a minor update....
-Wes
Old 04-07-2011, 10:27 PM
Kapusta's Avatar
Kapusta Kapusta is offline
Kapusta is a name known to allKapusta is a name known to allKapusta is a name known to allKapusta is a name known to allKapusta is a name known to allKapusta is a name known to all
I almost thought this was going to be a thread about what's wrong with O'Reilly's.
Old 04-07-2011, 10:55 PM
GBuckert's Avatar
GBuckert GBuckert is offline
GBuckert is starting off with a positive reputation.
I'll trade ya, I'm pretty sure every seal on my engine is leaking. The bottom of the engine doesn't stay clean long enough for me to track any down.
Old 04-07-2011, 11:06 PM
hammerhead90's Avatar
hammerhead90 hammerhead90 is offline
hammerhead90 is gaining momentum as a positive member of FTE.hammerhead90 is gaining momentum as a positive member of FTE.
Quote:
ditto.......
I only recently fixed the coolant leaks (yes that is plural) just as by brakes have begun to leak from two places
Old 04-07-2011, 11:26 PM
GBuckert's Avatar
Luckily the brakes and coolant are good for me and I just fixed an axle seal. I just happen to have oil and tranny fluid coming out of every imaginable crevice.
Old 04-08-2011, 12:02 AM
Nealcrenshaw's Avatar
Nealcrenshaw Nealcrenshaw is offline
Nealcrenshaw is starting off with a positive reputation.
I thought i was the only one with a multiple oil leak. Rear main and the oil pan.
Old 04-08-2011, 12:44 AM
Gotcha there Kapusta.....The oil is a VERY VERY small issue....Just a tiny drip....
-Wes
Old 04-08-2011, 01:21 AM
cj06's Avatar
cj06 cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
that's how i change my oil , after a month the truck has all new oil in it !
Old 04-08-2011, 10:27 AM
lupin398 lupin398 is offline
lupin398 is starting off with a positive reputation.
On my 300 a suspicious oil leak appeared, and I couldn't trace it down; Seemed to come from everywhere and kept just about everything from the coil back wet on the bottom.
It was the lifter galley on the driver side of the engine.
the Cork gasket went to pot and even had chunks missing, how any would get through the engine and not block something up is a mystery to me but from what I saw everything was nice and clean and no debris.
Cleaned up the cover, replaced the gasket with a rubber Fel-pro one and it came with new gaskets for the bolts; No leaks since.
Motor is out. What to re-seal? Jeepincj7 1994.5 - 1997 7.3L Power Stroke Diesel 4 12-30-2013 09:17 PM
Help! Leaking like a stuck pig!! blaze42069 1994.5 - 1997 7.3L Power Stroke Diesel 3 10-28-2010 07:35 PM
6.0 Coolant Leak / Coolant in Oil / What is Best to Do? Forest 6.0L Power Stroke Diesel 4 01-09-2008 09:05 AM
Ford-Thompson Slipper-Type PS Pump Overhaul Tips? Boltgunner 1973 - 1979 F-100 & Larger F-Series Trucks 36 04-17-2006 01:19 AM
Front Main Seal Tool? DT 466Man Ford Inline Six, 200, 250, 4.9L / 300 4 04-12-2005 05:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
