Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Ford bypass oil filter??
Old 04-07-2011, 06:50 PM
80broncoman's Avatar
80broncoman
80broncoman is offline
I saw in my 1994 ford spec book that ford had an option for a bypass oil filter mounted on the side of the frame it looked like.
anyone seen one of these?
If I find one I wonder if you can still get the filter elements for them.?
Old 04-07-2011, 07:36 PM
cj06's Avatar
cj06
cj06 is offline
should be a thread size , 1 1/16" , 1 1/4" x i think 16 or so and will be able to get a common filter !
Old 04-08-2011, 02:03 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
No parts catalog listing for a by-pass oil filter for a 5.9L.
Old 04-08-2011, 08:01 AM
HOTWRENCH's Avatar
HOTWRENCH
HOTWRENCH is offline
Talking By Pass Filter
I think what you are talking about is the Luberfiner type of bypass filters. They are a metal canister filter mounted remotely on the frame and connected to the motor with hoses. Replacement elements are available. The last big truck I seviced had a Luberfiner and I got all my filters at NAPA.
Have A Great Weekend ----- Hotwrench
Old 04-08-2011, 10:31 PM
80broncoman
Well maybe it is only a 8.3l option. It is listed in the 1994 F and B seriesDiesel owner guide that I bought on Flebay.
It says on page 205:
"to change element drain filter housing and replace filer with motorcraft or equivalent"
"Remove cover then unscrewT-handle pack hold downassembly......"
"Add 3 U.S. Gallons of oilfor diesel engines to the crankcaseto fill the filter caseand element. Loosen the cover vent plug and start engine. When oil reaches the vent close the plug. recheck crankcase oil level"
The drawing they show it liooks like it has a nice frame bracket.
3 gallons?!? dang this thing must be big. From Ford description it doesn't sound like a spin on filter either.
Old 04-09-2011, 05:16 AM
NumberDummy
There is a by-pass filter listed, but not for 5.9L's. Don't recall what engine it was available for.
When you asked about the by-pass filter element availibility, I went to the 5.9L's engine section in the '90/98 truck parts catalog to find...then list the p/n...there isn't one.
Old 04-09-2011, 07:58 PM
jpr38057's Avatar
jpr38057
jpr38057 is offline
It's a luberfiner cartridge filter like hotwrench said. The number used to be 750 and has been used for years but very few Fords trucks had them in the later years.
Old 04-10-2011, 09:43 PM
80broncoman
I trust your word 100% on ford trucks. Ifi did run across one of these set ups I'd still be very much temped to see how well it wold fit on mine.
I always have like the idea of a bypass filter system.
TerranE
21
01-03-2017 08:43 AM
Gatordog
10-24-2015 08:38 PM
Yahiko
09-26-2012 12:03 PM
NavyMIDN08
03-07-2010 03:51 PM
kupaa
74
01-28-2009 08:56 AM
Quick Reply: Ford bypass oil filter??
