HELP!! exhaust leak from flex pipe..... - Ford Truck Enthusiasts Forums
Old 04-07-2011, 07:34 PM
dan.alger's Avatar
dan.alger dan.alger is offline
dan.alger is starting off with a positive reputation.
Smile HELP!! exhaust leak from flex pipe.....
I have an 04 6.0 that was running real rough, took it to ford today they said it had multiple problems....
1) bad injectors in #2 and #5
2)injector control mod had been replaced, computer and mod were not undated to match.
3)They also said I have an exhaust in the "flex" pipe under the turbo, the mech said that it was leaking where the pipe is made to flex so it needs to be replaced. This is why my turbo lag was so bad...
I had them replace the to bad injectors and update the injector control mod problem and the truck now purrs like a kitty...no more missing and seems to run great.. The problem is I could not afford to fix the exhaust leak and my turbo lag is really bad until higher RPM's. Has anyone replaced this pipe? Whats the name of the pipe so I can purchase a new one? can an exhaust shop do it cheaper, ford wanted $1100....thank you
Old 04-07-2011, 07:52 PM
wulfman wulfman is offline
wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.
Dan.alger its not that hard to do the turbo has to come off and then unbolt the pipe sounds easy but the bolts on the pipe are a PIA . PartsGuyEd . com has the y pipe for 170 plus shipping under 2 bills to your house. I just did mine a couple months ago took me 2 weeks but 1 week for part and i cleaned the turbo while it was off and i am slow. You can do it in a weekend if you try.Oh would not left exhaust shop do it they could really F something up.
Old 04-07-2011, 08:01 PM
dan.alger's Avatar
thank you, I haven't personally looked yet but it is a y pipe? is it the only flex pipe off the turbo?
Also on ur mods you state you have a welded egr cooler, did you unplug ur egr and what did you weld up? Thanks, new to the diesel and trying to learn all that I can so I can improve mine....
Old 04-07-2011, 08:08 PM
Yes it is the only one . My egr valve is still in place and plugged in , the egr cooler is welded, the ends where exhaust enter and exit. water still flows though it this way it looks stock. Just a cheap way of doing egr cooler delete.
Old 04-07-2011, 08:37 PM
dan.alger's Avatar
first, I truely thank you for your advice and help........
Now, I have another question for ya
Do you pull your egr valve and clean? and how do you feel about just unpluging? Is this something I should be doing because I never have....
Old 04-07-2011, 08:44 PM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
The y-pipe is actually two sections with a flex in each. If it's leaking on the passenger side then all you need is the up-pipe section but I don't know if it's available from Ford separately. $1100 is ridiculous to replace it IMHO. I have a used up-pipe I'll sell for an excellent price if it's not available separately and you're interested.
Old 04-07-2011, 08:47 PM
2006powerstroke90's Avatar
2006powerstroke90 2006powerstroke90 is offline
2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.
Where I work we have 2 04's in our fleet of trucks.
Both of them have the same exact turbo lag problem.
But after they spool up they take off.
Are there any noticeable symptoms of the up pipe being cracked besides turbo lag..diesel fumes in cab? Any hissing?
Old 04-07-2011, 08:56 PM
dan.alger's Avatar
No hissing, just fumes in the cab...I haven't got under the truck to see for myself this is what the mech at ford told me. I'm not sure if it is the up or the down side....just really gutless till it spools
Old 04-07-2011, 08:58 PM
dan.alger's Avatar
I know what you mean, they charged me $1400 to replace 2 injectors thats is why I am on here looking for help.....
Old 04-07-2011, 08:59 PM
It's really not a bad job to attempt yourself of your comfortable working on things.
Probably should only take you a day. IMHO.
Take the turbo out, remove the clamps to the egr cooler, take the 4 13mm nuts holding the up pipe to the manifolds off and it should slide right up and out.
Old 04-07-2011, 09:05 PM
Also what Tyler said about fumes in cab, while its parked running with heat on do you smell fumes in cab. And yes egr valve needs to be kept clean. You also might want to read the tech folder a lot of info there and just reading other peoples threads slash problems has taught me a lot.
Old 04-07-2011, 09:59 PM
dan.alger's Avatar
Tyler, I just noticed in a earlier thread you had 2 injectors go and you were concerned that maybe your programmer had something to do with it. I just had to replace 2 injectors also and was curious if you have had any more issues since you put ur programmer back on? am I safe to do the same?
Old 04-08-2011, 05:54 AM
Nice Work Truck's Avatar
Nice Work Truck Nice Work Truck is offline
Nice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to behold
The Y pipe is just a PIA to do.
I did mine over the winter with a better unit from Elite Diesel.
It took me about 4 hrs.
Take the alt off and then I used these directions for replacing a turbo to get to the y pipe.
Also get the turbo o-ring kit for a dealer, it is like $20.
http://www.ford-trucks.com/ford-manu...%20Removal.pdf
Old 04-08-2011, 06:30 AM
Copedawg's Avatar
Copedawg Copedawg is offline
Copedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant future
Seems to me the junkyard would be your best bet.
Old 04-08-2011, 06:36 AM
Junk yard is not the place for this Y pipe needs to be new item
Turbo will not exceed 6lbs of boost jaymo8989 6.0L Power Stroke Diesel 11 06-01-2015 01:55 PM
Turbo will not exceed 6lbs of boost jaymo8989 1999 to 2016 Super Duty 0 05-31-2015 11:25 AM
Problems w/ EGR delete Fire85 6.0L Power Stroke Diesel 24 04-04-2012 10:59 AM
Oil coming out the Exhaust...Bad Turbo? Injectors garsm 1999 - 2003 7.3L Power Stroke Diesel 2 07-31-2011 05:21 PM
trouble shooting low boost scameron 6.0L Power Stroke Diesel 46 09-17-2010 08:46 PM
Tags
64, cylinder, e350, egr, exhaust, flex, flexi, ford, forum, head, leak, leaking, pipe, truck, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
