Parking Ramps
cool! can you give me an address? that would be helpful, as i'm a country bumpkin and get lost easily in the Cities.
Is your truck completely stock?
If so it will fit, but barely. Most parking ramps in the cities that I've found have a 7' (84") clearance, and your truck should be 80.8" tall according to Ford specs. But you will be scraping your antenna on the support beams. I've had mine in the parking ramp for the MoA.
Go for it, but you might want to remove your antenna.
Specs found HERE.
Specs found HERE.
I can't comment on that particular one, but I recently went to a Dallas Mavericks game at the AAC and had platinum level parking (was a freebie from work). The first floor had plenty of clearance, but levels 2 and above looked sketchy. Platinum parking was 2 and above... first floor was VIP. Since the parking was paid for and they didn't have other options with better clearance, they upgraded me and I parked with the rockstars
ford2go
11-07-2012 02:25 PM
