On board air compressor - Ford Truck Enthusiasts Forums
Old 04-07-2011, 04:42 PM
IDI Diesel IDI Diesel is offline
IDI Diesel is gaining momentum as a positive member of FTE.IDI Diesel is gaining momentum as a positive member of FTE.
Hey guys,
I know its been done before but I cant find how. I have a 7.3 diesel with air conditioning. I never run the A/C and it leaks so im not going to bother fixing it. Iv herad that people have turned the A/C motor into an air compressor to fill air tanks. I plan n doin this to run air horns and air bags. Any ideas how to convert the air compressor??
Thanks
Old 04-07-2011, 05:48 PM
bobbyjo9 bobbyjo9 is offline
bobbyjo9 is starting off with a positive reputation.
Havent done it but I would think it easy to plumb.. just run the charge line with a 1 way valve to a tank, replace the return line with a filter and use the AC clutch as the on/off switch. The part Im not sure about would be the lubrication since the R134 takes care of that in a closed system??
Old 04-07-2011, 06:05 PM
snaponprofile's Avatar
snaponprofile snaponprofile is offline
snaponprofile is starting off with a positive reputation.
I talked to guy who did it and he said his a/c pump eventually seized, I just bought a onboard air kit from horn blasters for air horns, tire inflations, use of nail guns etc.
Old 04-07-2011, 06:06 PM
cj06's Avatar
cj06 cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
Old 04-07-2011, 08:49 PM
Volvo92906's Avatar
Volvo92906 Volvo92906 is offline
Volvo92906 is gaining momentum as a positive member of FTE.Volvo92906 is gaining momentum as a positive member of FTE.
Yup I did it for a while. You need to manually oil the compressor because it was built to be oiled by the freon going through it and that is gone. I did it for a while and it worked well.. Mine eventually seized up due to age (happens even with working a/c systems) so I just switched to a stand alone compressor.
As for the semi compressor mod for a vehicle, thats pretty awesome but probably pretty expensive also. I have air shocks and horn on my truck... If I had more it might be a good thing to do the install.
Old 04-07-2011, 09:06 PM
been searchingaround and found kit. ems like a fair price. anybodyuse one before?Shocker 22X
Old 04-07-2011, 09:12 PM
cj06's Avatar
for that price i would fab up a york compressor , they are not lubed by the freon as they are lubed just like a engine ( splash lubed )
A/C Compressor Wont Disengage rla337 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 08-09-2013 01:54 PM
A/C Compressor Clutch Randle 1973 - 1979 F-100 & Larger F-Series Trucks 0 08-08-2012 01:11 PM
replace a.i.r pump with air compressor? nebechanezer 1987 - 1996 F150 & Larger F-Series Trucks 3 05-26-2012 07:34 AM
a/c compressor cutting out, but when on it blows ice cold TR6 1999 to 2016 Super Duty 12 07-25-2009 05:57 PM
How to turn an A/C Compressor into an on board Air Compressor IZZYAZ Cooling, Heating, Ventilation & A/C 4 04-10-2009 11:46 PM
Tags
69, 91, air, board, compressor, diesel, f150, f250, f350, ford, install, onboard, pictures, raptor, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
