F-250 Questions
As for your question about if you have a Power Stroke, one sure indication is if it is auto trans or manual. If auto then it is not a Power Stroke but an IDI diesel and I assume yours is auto from your question about tow/haul.
Can`t be 100% but pretty sure the IDI diesels were not offered with tow?haul mode.
There is a great diesel section on this site for any engine problems. It`s on down the main forum page from here. Check it out.
Well then, tow/haul mode was only for automatics.
Open the hood and look at the engine. Can you see the fuel injectors and the glowplugs, injector pipes running around the outside of the valve covers)? If you can then you have an IDI diesel. If the injectors and glowplugs are out of sight under the valve covers, then you have a Power Stroke.
Also if you look at the oil fill cap on the engine and the injector pump with a spagetti of hard lines coming from it is just behind it you have an IDI diesel.
The Power Stroke is electronically controlled fuel injection so uses a computer to run the engine.
If you go down the main forum page to the diesel section and click on the Power Stroke page for your year of engine you will get a ton of info in the Stickies on that page plus you can ask there about servicing/problems.
Mstewart
6.7L Power Stroke Diesel
07-10-2012 10:24 PM
Comanche1Star
21
05-30-2011 01:14 PM
Tangmus
12-17-2009 02:53 PM
F250r
11-09-2003 07:03 PM
