Blue Oval Saga Pt. II-Michelle - Page 41 - Ford Truck Enthusiasts Forums
  #601
Old 05-10-2014, 03:43 AM
75Three90's Avatar
75Three90 75Three90 is offline
75Three90 has a great reputation on FTE.75Three90 has a great reputation on FTE.75Three90 has a great reputation on FTE.75Three90 has a great reputation on FTE.
Awesome work wes keep up the good work
  #602
Old 05-16-2014, 02:06 PM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
Just a small update. Took Michelle in for the reaming 2 tires she needed.
$177.31 for 2, Mastercraft P235/75/15's mounted, balanced and the guy rotated the other new ones to the front for free.
Also, diagnosed 2 issues.
#1) The Axle Pivot bushings are SHOT. When I take off, I sometimes hear the classic "Clunk!" from it wiggling around. I already have the new bushings ($35.00? I can't remember) and the guy will install them for $80.00 (Sounds high, til you realize I have 0 air tools, no lift, and no truly level ground OR the ball joint press ($60.00-300.00) to do it with, and then the added part of me with back issues.)
#2) The truck kinda does a little "Bunny hop" when lightly braking from 35mph to a stop.
I had previously replaced the Rear Brake Drums with the new ones off Ethel, the 1994 F-150 I had previously (Was only installed 3 months before the accident). As I suspected, they were getting oblonged/worn in an elliptical shape, rather than round.
Cost for that is:
Labor for entire axle:$50.00
Turning each brake Drum down: $15/side, so $30.00
Brake Shoes: $35-ish (Gonna put Motorcraft on this time. I HATE the Wearever's from the partshouses.
So, to recap...Another $200.00 will have everything driving and stopping correctly!
*Also, Michelle turned 219,000 miles old yesterday.
  #603
Old 05-16-2014, 07:48 PM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
That's sure better than $200 each and every month on a new vehicle!
  #604
Old 05-16-2014, 08:10 PM
blue924.9's Avatar
blue924.9 blue924.9 is offline
blue924.9 is starting off with a positive reputation.
wes any chance you got the courser at/2 tires by mastercraft
  #605
Old 05-18-2014, 11:37 PM
Quote:
I just know they're Mastercraft A/T's and I love them...lol.
I'll be sure to check them out tomorrow for you.
  #606
Old 06-01-2014, 02:12 AM
Michelle is 220,000 miles old!
She finally is 220,000 miles old now; Actually is about 220,400 atm.
Did a small trip the other day; 251 miles and filled up for 12.8 gallons which equals 19.6 mpg in very mixed conditions and a HOT day.
  #607
Old 06-04-2014, 10:39 AM
Yesterday I picked up a pack of fuses and went through my fuseblock, sorting it out.
Now all the fuses are correct and got my Power Point sorted out; The plug had gotten bad. But now it's all working again, just need to toss a new plug in.
Slowly getting things ready to simply replace every part of the AC System except the Compressor and Condenser.
  #608
Old 06-06-2014, 12:51 AM
Today I went to a friends' house and checked the compression on 5 of the 6 cylinders (It got too dark for #6).
Here's my findings:
#1: 137 psi
#2: 133 psi
#3: 133 psi
#4: 133 psi
#5: 150 psi*
All plugs were roughly .054" gaps; So I just re-gapped them at .054" and called it good.
Upon pulling the #5 Plug Wire off the Plug, the little metal connector out of the boot. So no idea how long it's been like that. Friggin' Duracrap Plug Wires.
  #609
Old 07-18-2014, 06:02 PM
As of 5am this morning, I smacked the hell out of a frickin' deer with mine.
Luckily, it just caught its head and knocked it away.
randomly and amazingly, it didn't hurt anything but to crack a turn signal lense (I have a spare set) and it shattered the HOUSING of the D/S Headlight. Lens was intact, and no issues. WTF.
Anyways...I'll fix it when I can.
Oh, and Michelle rolled over to 222,088 miles in the driveway this morning.
  #610
Old 07-26-2014, 06:24 PM
222,450 miles
Greased the hinge area of my tailgate and did some lubing of the handle pivots as well.
no more hanging tailgate handle, and everything latches/moves like day 1 again.
Also cleaned the cab out, and did a thorough cleaning of the windshield.
On another note, I'm up for another oil change.
  #611
Old 08-12-2014, 04:02 PM
222,900 Mi
Rotated the tires RF to LR and LF to RR. Next rotation will be Front to Rear.
Still needing an oil change; But today I removed the fiberglass portion of the Cervini's hood, and the wheel arch trim. Seems the trim has been allowing rust to propagate.
  #612
Old 10-02-2014, 08:31 AM
226,500mi
My inner pinterest ***** kicked in at work last night...
This is the final product from last night. I really couldn't see paying $50-100 for another 22 year old Dash Pad that'll inevitably crack just like this one did.
So my inner Pinterest-man came out in me at work last night.
Less than $10 and still have a ton of fabric left over to do my Map Pockets. Will need 2 more yards to re-cover my Headliner... Still less than $15.00 though.
Also, painted my E brake assembly and pedal "Arms" with gloss black paint:
  #613
Old 10-02-2014, 08:58 AM
ewalt98's Avatar
ewalt98 ewalt98 is offline
ewalt98 is gaining momentum as a positive member of FTE.
Cool;
My wife walked by and commented on the dash cover....she approved
  #614
Old 10-02-2014, 09:13 AM
Quote:
Originally Posted by ewalt98 View Post
Cool;
BAHAHAHA! That's awesome.
  #615
Old 12-13-2014, 02:02 PM
New Alternator @ 231,xxx miles (12-13-2014)
Truck is up and running.
Charging at a HEALTHY 14.32v at the Battery.
The alternator (A reman'd Motorcraft unit) had failed.
Total cost so far:
-$40.00-Diagnosis/Troubleshooting by Bill Harper @ Harper's Garage
-$115.30-Tough One brand 80amp Alternator from Advance Auto (ick!)
$145.30 total, and me installing the "new" Alternator myself (Literally took me $15 minutes TOPS
I was on the right track with the troubleshooting, using my personal knowledge of the truck and mechanical skills; I simply had no actual tester.
Although I'd metered the output voltage at like 8.42v while the truck was running. I simply wasn't sure if it was the Alternator itself; or the Exciter Wire (Known issues for this era Ford Truck) had a short.
"Gran"dad's truck build jstitts 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 50 08-05-2015 11:22 AM
1998 Aluminum Ford Crown Victoria Driveshaft Shortened clintonvillian 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 11-29-2013 06:01 AM
Here it is. 76 f250 2wheel drive converted to 4x4 with stocks parts torch4801 1973 - 1979 F-100 & Larger F-Series Trucks 15 07-17-2013 02:51 PM
Power Inverter Install (long w/ lots of pics) patrick77598 1999 - 2003 7.3L Power Stroke Diesel 35 01-09-2013 01:32 PM
Extang Soft Tonneau Review SideWinder4.9l Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners 3 06-05-2011 01:21 AM
Tags
1992, 1996, 2006, build, code, coupon, f150, f250, f350, financial, ideas, lmc, member, mpg, powered, project, regional, truck, v6, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
