Blue Oval Saga Pt. II-Michelle
#482
#483
I'm in Plymouth MA, America's Hometown I'm not talking about the entire hub/cap, just the little plastic hub center on the rears. I'm pretty sure they can be removed and the hubs/caps that go around the manual 4wd hubs are exactly the same without the little plastic cap.
Ok...
I'm sure shipping wouldn't be an issue then...
let me mull it over, and I'll let ya know...
#484
yes those "plastic things" can be removed, and are small enough to toss in a USPS medium shipping box (square one) and send off...i already lost one (think it came off on the road some place) and need to replace the things anyways...
#486
#487
The rest just went past the rust to good solid metal.....Then painted it, and called it even...
Check around...You'll be looking for a door code of H9=3.55 LS rear gear (4x4's have a numerically lower gear...3.55 rear, 3.54 front..)
Any door jamb sticker than has the H in the axle code, is a LS unit...
As for the actual differential tag...3L55 is the ticket...Or any that has a L in the numerical sequence....It'll be the lower set of numbers, next to the bolt holding it down...
#489
#490
#491
5-7-2012 Michelle's 4x4 Update
Well, here's what I've accomplished so far today-
- Cleaned/painted the Differential Fill Plug
- Removed the Retaining C-Clips for the Center U-Joint
- Removed 1 Cap...
- Dropped the entire front end on my foot (Thank GOD for steel toed boots)
- Picked up said front end myself (BARELY)...Pulled my back pretty bad..
#493
Michelle Update 6-26-2012
Ok guys....2 months...Plenty of work has been done...Here goes...
First off, I have ordered-
New shocks, Axle Pivot & Radius Arm Bushings, replaced both fuel pump strainers....
Here's some pics...
And here's some other things I've done...
Cleaned the rims up nice...
And added a Powerstroke Diesel Bumper...$30...
Just gotta put the D/S Spindle back on, and get the Axle Pivot Bushings pressed in, and the Differential is DONE....
Here's other things I've been fixing...
-Front Fuel Pump, Strainer, etc...
And here's the new Strainer...
And here's what I did for the rear tank....Same thing...Replaced the strainer...
But here's what I found...
The strainer literally fell off as the pump came out...
Made a new Differential Seal...
Here's some pics...
#495
