1996 f-150 eddie bauer 5.0 engine tapping - Ford Truck Enthusiasts Forums
Old 04-07-2011, 07:44 AM
usnretired2002 usnretired2002 is offline
usnretired2002 is starting off with a positive reputation.
at highway speed while on crusise control loose of power and cel flashed then stayed on pulled over visual check okay.restated with what souded like tappet tapping. did compression check all good but #3 had zero compression did air test and decided burnt valve. with 160,000 on motor decided to have overhauled vaulve had over travelled and hit top of piston and dinged it do i have a bad cam or bad roller lifter? reason im asking is problem happened after only 2500 miles on rebuild. And I did not do overhaul. but will do this one and want ideas on where to checkfirst. all help appreciated. i was a diesel mech. in the Navy for 20 years and will find the time to fix it right this time as I love this truck. Too bad ford doesn't have a small Fairbanks-Morris engine in them as am real familuar with them.
Old 04-07-2011, 08:10 AM
DBGrif91's Avatar
DBGrif91 DBGrif91 is offline
DBGrif91 is gaining momentum as a positive member of FTE.DBGrif91 is gaining momentum as a positive member of FTE.
I guess I'm a bit confused- or maybe I'm just not reading it correctly.
You're saying that you had a valve over travel and hit the piston, then had the motor overhauled, then had the same problem happen only 2500 miles into the overhauled motor, correct?
If I'm getting this right, to what extent was the motor overhauled, and is there a warranty on the work? If so I'd have the working party fix it- I can't see a warranty expiring after only 2500 miles.
I also want to thank you for your service to our country. You guys are awesome.
Old 04-07-2011, 05:43 PM
reply
it was early in the morning coffee hadn't kicked in. same problem after a overhaul by a shade tree mech.( I don't have a shop and it was winter time,he was resonablly priced) valve job,oversized rings and new bearings,cyclinders honed. I plan to do the work my self minus the head as i can get it done faster than I can do it. only looking at the cam and roller lifters as the problem unless someone has better plans, am open for suggestions. also the one year time frame for the warrenty had passed.
Old 04-07-2011, 05:46 PM
the one year warrenty had expired
New Engine Prices in AK 05F350CC Alaska Chapter 1 07-18-2015 11:43 PM
I Went to Alaska grinnergetter 1973 - 1979 F-100 & Larger F-Series Trucks 32 09-10-2014 09:43 PM
Advice on operating a 7.3 at -60*F 90pioneer 1999 - 2003 7.3L Power Stroke Diesel 9 08-08-2014 04:55 PM
New Super Duty guy DomsF250 New Member Introductions 2 07-22-2014 03:25 PM
Tags
1986, 1996, 50, 96, bauer, bower, eddie, eddy, engine, f150, ford, motor, sale, tap, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
