DJM Suspension HS1123-4 - Ford Truck Enthusiasts Forums
Old 04-07-2011, 03:54 AM
Evilution's Avatar
Evilution Evilution is offline
Evilution is starting off with a positive reputation.
have any of you used it? i wanted to get itbut the i noticed it says standard cab only on the summit website? im assuming this is a typo. makes no sensse as the single cab has no different suspesion set up than the ext cab. and the shackles that come in this kit say they work on both ext and single cab. yall think im safe buyin it? or should i just stick with the 2 inch drop
Old 04-07-2011, 05:45 AM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
That should work , can't see why it would not....
Old 04-08-2011, 12:33 AM
Evilution's Avatar
Quote:
Thanks man i went ahead and ordered the kit and shocks. i let yall know how the install goes i sure hope they work. can t imagine that a single cabs rear suspension hangers and shackles are any diffeent than that of an ext cab
Old 04-08-2011, 01:54 AM
hav24wheel's Avatar
hav24wheel hav24wheel is offline
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
Only thing I could figure is the wt rating of the springs themselves would be heavier on a extended cab. (That's the case with the 4x4s in lift kits)
Drivetrain Swap Quesiton thethrill 1987 - 1996 F150 & Larger F-Series Trucks 1 03-18-2016 09:02 AM
What to look for? Grizzly4x4 1987 - 1996 F150 & Larger F-Series Trucks 2 04-30-2015 01:22 PM
Plowing with a 93 f150 4x4? Firstonraceday93 1987 - 1996 F150 & Larger F-Series Trucks 10 10-10-2011 07:17 AM
92 5.0 5 speed sloppy shifting insideout414 1987 - 1996 F150 & Larger F-Series Trucks 13 03-06-2010 05:56 PM
Fitting kicker compvx in single cab Extacie Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 53 07-13-2009 06:09 PM
Tags
djm, ford, forums, hs11234, part, suspension, suspensions
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
