Lincoln trans in truck? - Ford Truck Enthusiasts Forums
Alberta Chapter Join Chapter, Leader: Puddy
Old 03-18-2003, 09:40 PM
Islandguy61 Islandguy61 is offline
Islandguy61 is starting off with a positive reputation.
Hi I am trying to put my truck back together but am having problems. I got the 460 and C6 trans from a donor Lincoln and the motor fit in fine But the trans is 2and1/2 inches longer and mounts differently So I am wondering if I can remove the tailshaft and replace the rear output shaft on the trans and install a shorter rear part on the trans or do I have to replace the whole trans ? I have 2 other C6 trannys that are differrent bellhousings BUT have right length to them. Please anyone Let me know or tell me its not going to work so I can get on with it!!
Love the truck but it is like a girlfriend its real needy lately
Old 03-18-2003, 10:47 PM
Farmers Ford Farmers Ford is offline
Farmers Ford is starting off with a positive reputation.
I'd say take your lincoln tranny and one of your spares that would fit in your truck aand transfer the guts into it, no mods to the truck or anything.
vance
88 Lincoln motor w/ AOD trans granny_rocket 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 03-31-2013 11:55 PM
4.6 DOHC wiring kstones63 Modular V8 (4.6L, 5.4L) 4 11-09-2010 05:29 PM
1971 460 swap lugnutx2 1967 - 1972 F-100 & Larger F-Series Trucks 9 08-14-2009 11:50 PM
AOD to C4 or C6 ?? Hillcrest#9 Clutch, Transmission, Differential, Axle & Transfer Case 7 02-28-2008 03:41 PM
Removeing C-6 (and engine) from old Lincoln, help? Tsaven Nava Clutch, Transmission, Differential, Axle & Transfer Case 2 04-14-2006 02:14 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
