Oil pressure sending unit location? - Ford Truck Enthusiasts Forums
Old 04-06-2011, 11:09 PM
BigBlue92 BigBlue92 is offline
BigBlue92 is starting off with a positive reputation.
Was wonderin where the oil pressue sending unit is located in a 1992 F150 with a 302. Any help is appreciated.
Old 04-07-2011, 12:10 AM
86F150302's Avatar
86F150302 86F150302 is offline
86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.
Right in front of the oil filter. Behind the AC/PS bracket.
Old 04-07-2011, 08:22 AM
Alright. Will replacing this fix my oil pressure gauge? The needle on my gauge is always showing completely low oil pressure. When i take off from a stop, it moves to about mid range and then goes right back to low.
Old 04-07-2011, 10:10 AM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
Maybe. Just be aware that your OP gauge is not really a gauge, it's an idiot light. The sender is only an on-off switch that comes on at 7 psi. There is a resistor on the back of the gauge that makes it read in the "normal" range when grounded by the sender.
Old 04-07-2011, 04:41 PM
86F150302's Avatar
It should fix it. Really no point in replacing it. Just put an aftermarket gauge in.
My stock gauge shows very low all the time but my aftermarket is at 60psi..
Old 04-07-2011, 06:04 PM
nstueve's Avatar
nstueve nstueve is offline
nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.
or just do the conversion and jump the wire on the back of your cluster and put a real OP sending unit in from say... a 85 302... There are tons of threads on here about how to do the conversion. then you get an actuall variable pressure reading on your stock cluster guage.
351M oil sending unit locations 1979 300i6 1973 - 1979 F-100 & Larger F-Series Trucks 3 07-15-2014 07:17 PM
Oil pressure sending unit location 3.0 DaytonaTunnel Ranger & B-Series 2 06-22-2014 06:06 PM
oil sending unit fooledagain 1987 - 1996 F150 & Larger F-Series Trucks 8 10-01-2012 10:15 AM
4.2 oil sending unit location ARK Ranger 1997 - 2003 F150 2 02-11-2012 02:39 PM
Location of Oil sending unit bubbasz1 1999 to 2016 Super Duty 2 11-18-2008 11:47 AM
Tags
20, 2001, 351w, 58, bronco, diagram, escape, ford, liter, location, oil, pressure, sender, sending, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
