My new fuel tank vent set-up - Ford Truck Enthusiasts Forums
Old 04-06-2011, 04:42 PM
Lukes66's Avatar
Lukes66 Lukes66 is offline
Lukes66 is gaining momentum as a positive member of FTE.Lukes66 is gaining momentum as a positive member of FTE.
I haven't fueled up yet but I thought I would share what I did with my tank vents. Many 6.9 trucks have a slow fill issue due to poor venting, also the truck will not take a semi truck style diesel nozzle with the stock filler neck intact.
I removed all of the "guts" from the inside of the filler neck, then I replaced my rollover valves with some nylon elbows that are actually pcv elbows. I routed the 19/32 fuel line vent to the plastic filler housing where it vents.
According to my primitive measuring, it will clear no problem (these elbows are only around a .25 inch taller than the stock rollover valves). Hopefully it will take fuel at a reasonable rate. Now I just have to make sure I don't roll it over!
Old 04-06-2011, 04:51 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
That's how I did mine on my diesel, and it works very well. I didn't have those nice plastic elbows though. You may still get a little contact on the rear elbow to the bottom of the bed. It's very tight in that area.
Old 04-06-2011, 04:55 PM
Lukes66's Avatar
One last pic here... This is my new LMC rear sending unit and pick up!
Old 04-06-2011, 05:57 PM
billt28's Avatar
billt28 billt28 is offline
billt28 is gaining momentum as a positive member of FTE.billt28 is gaining momentum as a positive member of FTE.
Does a diesel have the canister in the engine compartment?
Old 04-06-2011, 06:03 PM
Lukes66's Avatar
Quote:
no, they do not have a vapor canister.
Old 04-07-2011, 03:15 PM
1986F150six 1986F150six is online now
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
The sending unit is from LMC, but I see FORD on the label.
Old 04-07-2011, 04:25 PM
glovemeister glovemeister is offline
glovemeister is gaining momentum as a positive member of FTE.glovemeister is gaining momentum as a positive member of FTE.
I'm curious as to how this can be done with the vent inside the filler neck on the gas pickups?
Old 04-07-2011, 07:10 PM
Franklin2's Avatar
Quote:
No need to do this on a gas pickup.
Update on my progress last week.. lots of pics Lukes66 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 19 05-15-2016 01:24 AM
got my cab lights installed.. Lukes66 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 02-15-2013 11:17 AM
Painted My Headliner, What You Think? BiltFordTuff 1973 - 1979 F-100 & Larger F-Series Trucks 28 04-19-2011 09:06 PM
Stock Truck Pics mark293 1987 - 1996 F150 & Larger F-Series Trucks 48 02-10-2011 10:32 AM
Homemade Crossmember? PTO Transmission? Pics Lukes66 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 08-31-2009 08:39 AM
Tags
1966, 1989, 1995, codes, f100, f150, f250, fill, ford, fuel, rear, sets, slow, tank, testing, truck, vent, vents
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
