what type of transmission fluid should I use? - Ford Truck Enthusiasts Forums
Old 04-06-2011, 04:13 PM
hatchet's Avatar
hatchet hatchet is offline
hatchet is starting off with a positive reputation.
my transmission fluid is low since I have a small leak that needs to be fixed. but its been so long since since I had put any in I forget what type of tranny fluid to use?Its dexron 2 right?but does it matter what brand?is one better than the other?my truck im putting it in is a 95 f 250 4x4 351w with a E40d.
Old 04-06-2011, 05:32 PM
Nevada Al's Avatar
Nevada Al Nevada Al is offline
Nevada Al is starting off with a positive reputation.
Mercon V, (any current name brand will be to Ford specifications)...while your at it drain it and the converter completely, throw a new filter in it, and put all new fluid in it...Your tranny will thank you..
Old 04-06-2011, 06:42 PM
hatchet's Avatar
thanks can it be Mercon/DextronII or Mercon/DextronIII ? im guessing 2? thats all the parts store had it said Mercon/DextronII or Mercon/DextronIII 2 right?thanks again and yes I will change the filter and fluid while im at it good info.
Old 04-06-2011, 09:13 PM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
As said above Ford says to use Mercon V.
1997 F250 E4OD Transmission Fluid Problem kcoburn1 1987 - 1996 F150 & Larger F-Series Trucks 6 08-07-2015 05:56 AM
Front/Rear Axle and Transfer case oil change questions? bigblockford_390 1999 - 2003 7.3L Power Stroke Diesel 4 03-11-2012 02:58 PM
Which fluid to use in a Ford O Matic? cars2cool 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 06-14-2010 10:14 AM
help-- transmission fluid tag187 1999 - 2003 7.3L Power Stroke Diesel 1 07-19-2008 10:02 PM
Tranny Fluid question trvaughn Clutch, Transmission, Differential, Axle & Transfer Case 2 01-31-2007 10:47 AM
Tags
13, 2005, 2008, 86, book, chapter, dextronii, expedition, f250, fluid, ford, hatchet, kind, speed, trans, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
