EGR delete on '06? - Ford Truck Enthusiasts Forums
EGR delete on '06?
Old 04-06-2011, 03:04 PM
scrdanis scrdanis is offline
scrdanis is starting off with a positive reputation.
EGR delete on '06?
I have an 06 PSD 350. I have purchased the EGR delete kit and the oil cooler as well. Before I install them I was wondering the out comes in regards to performance from others after the delete. I hear of "limp" modes that the engine goes into and am not sure if a delete is the way to go. I am not interested in losing more power but MPG increase would be great.
Old 04-06-2011, 06:42 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
you will get no incress in mpg or power. you will/ may have a reduction in boost levels... reduced boost is not always abad thing. the power level will be about the same.
you will have a check engine ligh t if you dont trun off the erg valve function in the pcm.
EGR Delete Lee44054 6.0L Power Stroke Diesel 1 04-26-2014 06:10 PM
EGR Delete sglass57 6.4L Power Stroke Diesel 13 05-01-2013 07:33 PM
Decent egr delete Poorboy04 6.0L Power Stroke Diesel 7 04-22-2013 08:05 PM
EGR delete or EGR block? brkncly 6.4L Power Stroke Diesel 3 08-02-2012 08:25 PM
EGR Delete kit vote tolliewolly 6.0L Power Stroke Diesel 17 03-24-2010 09:00 PM
Tags
06, 60, 60l, air, code, delete, diesel, egr, f250, ford, hear, increase, limp, loss, mode, power, www06ford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
