95 psd - where to look for leak (pics)
I recently bought a well used 1995 F350 powerstroke. It has an oil or fuel leak near the firewall dripping down. I believe it only leaks while running. It is my understanding that this is usually something that originates in the valley, around the hpop or the pump itself. The engine is wet with oil there and it seems to be where it is coming from. It seems that there was a previous leak on the drivers side as well, but it seems to have been repaired (although not cleaned up). I thought I would post a few pictures for the keen eyes on here and hope to get some info or opinions. Please feel free to point out anything at all as I am new to owning a psd. Thank you all in advance, Jimbo.
Backed up to show the leak (after three days of sitting in that location):
Engine cover off:
Intake Valley:
Underside:
Engine cover off:
Intake Valley:
Underside:
OIL LEAK
Hi, that looks like my truck after cleaning valley,working on HPOP plug on the
bottom s soon i get parts,replaced fuel lines not long ago,after looking at
numerous posts about this problem it appears to be the only place it can leak
this bad unless there is another place,it eems like not a hard job just pain to do,thanks
About all you can do is clean it up with some simple green or something, no pressure hose, just rinse it off lightly, get it clean. Then start it and stand on your head with a mirror in places and look for leaks. Maybe need to put some paper towels around to find the leak if its not bad.
If oil could be hpop orings, turbo pedestal orings, hpop lines, etc.
fuel could be pump, bowl, regulator, lines, etc.
In other words, it can leak in a lot of places, just gotta determine where its at.
oil leaks
Hi, one thing i thought about the other day is using one those tools for looking behind walls in houses i have one but have not tried it,but its got a light and a viewing screen that lets you see what there. The one i have is made by RIDGID called a sea snake. This one has a flexible line that bends.
oil leak
Hi,i just pulled my hpop apart,took plug off found o-ring split and plug almost finger tight,but what worries me is i thought there was a spring and check ball under plug is this right and if it is wheres mine as when i pulled plug it was upright and i looked in hole and there was nothing in there,thanks.
Getting ready to put back together need answer ASAP.
