slave cylinder line removal tool - Ford Truck Enthusiasts Forums
Old 04-06-2011, 09:22 AM
octaneforce's Avatar
octaneforce octaneforce is offline
octaneforce is starting off with a positive reputation.
what tool do i need to remove the line from the clutch slave cylinder when i drop the tranny on my truck? im doing my clutch this weekend. its like the fuel filter fitting, right?
Old 04-06-2011, 03:11 PM
F150xlt F150xlt is offline
F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.
All you need is two flat blade screwdrivers and an extra
set of hands.
With the release tool or two flat blade screwdrivers,
press inward on the plastic bushing that surrounds
the plastic hydraulic line until it bottoms out.
When you press on the plastic bushing, it spreads
some metal springy fingers outward which allows
the removal of the plastic hydraulic line.
Here the release tool made by KD tools. You could easily
make your own. Some clutch kits include the tool.
Old 04-06-2011, 03:24 PM
Kapusta's Avatar
Kapusta Kapusta is offline
Kapusta is a name known to allKapusta is a name known to allKapusta is a name known to allKapusta is a name known to allKapusta is a name known to allKapusta is a name known to all
I just used an open end wrench to pop mine. I don't recall the size at the moment.
Old 04-06-2011, 04:26 PM
Duct Tape Racing's Avatar
Duct Tape Racing Duct Tape Racing is offline
Duct Tape Racing is gaining momentum as a positive member of FTE.
Quote:
x2 on that. i used one big enough to fit over the line
Clutch line popping off slave cylinder templars Ranger & B-Series 3 07-07-2015 09:35 AM
1991 F150 clutch slave removal dconrads 1987 - 1996 F150 & Larger F-Series Trucks 3 01-08-2015 10:32 PM
Clutch Slave Cylinder reloaderbill 1994.5 - 1997 7.3L Power Stroke Diesel 6 01-24-2014 03:26 PM
slave cylinder removal octaneforce 1987 - 1996 F150 & Larger F-Series Trucks 19 05-02-2011 11:30 PM
Clutch Hydraulic Line Removal 1982fordf100 1987 - 1996 F150 & Larger F-Series Trucks 3 01-25-2004 02:49 AM
Tags
1994, 87, 96, bronco, clyinder, cylinder, cylnder, cylnider, f150, ford, line, removal, slave, tool, tools
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
