Another no start WITH A TWIST!!!
Ok guys got another no start. It cranks super slow. Batteries are not even 6 months old and new starter and all that.
This is my problem other than not starting.
This pic is the wire that goes from the ground on the battery to the fender well to the voltage regulator. The wire melted.
Will this cause a slow crank and no start problem that I am having?
sorry for the crappy pic it was getting dark outside.
Charge your batteries and make sure the are fully-charged.
Then go around, loosen all your electrical connections and wire-brush/sand/file them for clean surfaces.
You'd be surprised with the difference whent he second battery on my truck actually received a good connection thru the second battery terminal. It seems like some ding-dong mechanic (ME!) didn't tighten it last time....
I don't think that wire will have anything to do with starting.
Starting the truck means supplying 12v of power to the starter solenoid (mounted on the inner fender). This sends power from the batteries down the starter.
It's incredibly simple, the voltage regulator will be involved in charging...not starting
surfaccing
04-22-2013 08:46 PM
Shmit90051
01-23-2013 10:20 PM
79fordf250pickup
02-08-2012 11:28 PM
