5.4L 4x4 Broke rusted dipstick tube - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-05-2011, 09:04 PM
dillenger1 dillenger1 is offline
dillenger1 is starting off with a positive reputation.
Got a truck with a rusted dipstick tube in the pan.Ive removed the manifold to do that while im at it.removed the motor mount.ive tried removing with a tap but the tap snapped off in the bottom.Im removing the oilrail or trying to.Is there anything im missing besides the obvious bolts.I smacked it pretty good.Its a plow truck so everythings pretty fused.
Old 04-05-2011, 10:07 PM
twall_SD250's Avatar
twall_SD250 twall_SD250 is offline
twall_SD250 is starting off with a positive reputation.
i dont have any input for you but let me know how you make out. i have the same problem but my rotted off right above the mounting bracket. i had my buddies shop look at it but he was afraid if he tries getting it off without removing the manifold it might snap off at the oil pan. he told me if it breaks off flush he would have to drop the oil pan and push it out that way. but as we know you can just drop the oil pan without raising the motor up.So you have a $14 part and hundreds in labor.
Old 04-05-2011, 11:14 PM
ganzey ganzey is offline
ganzey is starting off with a positive reputation.
same thing happened to me. when i bought mine it was broken off flush with the engine. a couple of bolts on the oil rail are REALLY hidden, get a mirror to help.
What i did
-remove engine mount
-remove oil filter cooler thing
-did NOT remove exhaust manifold
-threaded a tap into the tube, then heated the **** outta it, grabbed the tap with vise grips, and pounded it out.
while i was at it i notice the lower radiator hose was rubbing on the frame and almost worn through, replaced that
also you will need the oil filter mount gasket
the WORST part, was rocking the engine to the passenger side to remove the oil filter cooler thingy, and pounding out the old one.
overall we spent 7 hours taking it out, 3 to get it all back together. just take your time
Old 04-07-2011, 06:02 AM
anyone know what the combination gasket is called for the lower coolant inlet/oil feed return at the parts store?They were baffled when i went up there
Oil dipstick tube rusted off at engine. knightrider955 Modular V10 (6.8l) 11 06-05-2015 11:41 AM
7.5l dipstick tube? qumanchew 1987 - 1996 F150 & Larger F-Series Trucks 25 03-25-2014 03:50 AM
Another dipstick tube issue aphotic26 6.4L Power Stroke Diesel 2 12-05-2013 12:59 PM
Rusted oil dipstick carlforman 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 07-11-2012 06:16 PM
Oil Dipstick Tube Bolt SIZE??? Jacobjj85 1997 - 2003 F150 2 05-22-2009 11:21 AM
Tags
1999, 42, 54, 54l, dipstick, engine, f150, f250, ford, liter, litre, oem, oil, rust, tube, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
