We need more info please.
What engine? 4.6L 5.4L
What happens after it starts?
I just noticed you wrote F-250.
Try the SD forum.
This is the '04-'08 F150 forum.
That's why nobody has answered.
Try the SD forum.
ive listed it in 4 places looking for a ford mechanic year dont matter that much if you no the fix
no codes all started after using that sea foam crap in fuel system and pouring in vacuum lines, truck will start if fuel is squirted into air intake then searches for idle, have not tried pedal to foor yet, its rich when trying to idle,will bei checking fuel system just trying to get all areas to check for probs for this weekend s work
I would start by checking for vacuum leaks. Than I would look at the IAC. Why did you Seafoam in the first place? Was the truck running poorly or missing?
Accelerator to floor when starting cold might help cold start. Sounds like it's flooded out for some reason. Probably IAC. You can remove it and clean with MAF/ throttle body cleaner. That might do it. Or you may have to replace it.
