shorty headers
on
You need truck headers a set from a Mustang won't work, any truck shorty would fit the engine in any series(f150, F250, F350 etc) except where smog equipment is concerned since the HD trucks had different connection points for the air tubes. If however you were eliminating that stuff then it's not a concern and you could use a set designed for an F150 for example. For ultimate durability stainless is the way to go with ceramic coated next best.
on
A 5.0 truck header will bolt to the engine no problem(same head) but it may not allign perfectly with the Y-pipe since the 5.8 block is taller and wider and it won't have a fitting for the EGR tube at the front passenger side. Power gains could range from next to zero if the stock cats remain to 10-15hp/tq with aftermarket high flow exhaust systems.
gildardo01
06-21-2013 05:19 PM
highoctane74
04-24-2010 12:55 PM
danger-ranger93
03-24-2010 04:30 PM
sliphersford
07-04-2004 11:27 AM
