Cab floor question, 1987 vs. 1988+ - Ford Truck Enthusiasts Forums
Old 04-05-2011, 06:41 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Question Cab floor question, 1987 vs. 1988+
I noticed something I hadn't before in my Parts truck CAB.
The cab is a 1987, and doesn't have a mold on the SIDE of the floor hump for a 4x4 shifter. I know that was the last year for the old style 4x4 shifter coming through right behind the transmission shifter on the removable floor hump.
Does anyone know for sure if a 1988 cab would have the molded floor on the side of the hump for a 4x4 shifter?
I know my '89 F150 2wd C6 does have that mold as I removed the vinyl floor last summer to pressure wash it.
Old 04-06-2011, 03:58 PM
No one????
Old 04-06-2011, 04:33 PM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
Are you refering to the location in the floor where the removable flooring goes? Most 80 to 91 trucks had either the removable floor with manuals or solid floor in automatics.
The one cab I was going to use was a 87 which did not have the removeable floor as it was a automatic 2x4. It did have the stamping in it but not cut out. So I could air saw it out and use the removeable floor.
Now the removeable flooring are diffrent from the few I had, the 4x4 had provision for the xfer case leaver, the 2x4 did not. Not sure about any diffreneces between the years. But they all will fit in the flooring with no issues.
I do have a photo of the 87 cab, don't show much but you can see were the removeable floor would go.
Old 04-06-2011, 04:35 PM
I'm talking about the mold on the side for the 4x4 shifter.
My 2wd Auto 89 F150 with solid floor does have one.
Old 04-07-2011, 11:01 AM
john_1956. john_1956. is offline
john_1956. is starting off with a positive reputation.
cab floor
My 88 does have the left side hole for 4x4 shifter 87 does not
78 f150 floor rebelson88 1973 - 1979 F-100 & Larger F-Series Trucks 16 12-11-2014 02:25 PM
Ebrake change - from foot pedal to hand pull handle - yay or nay? four-sixty-power 1973 - 1979 F-100 & Larger F-Series Trucks 1 10-17-2013 07:35 AM
1963 F100 4x4 Transmission KsCop 1961 - 1966 F-100 & Larger F-Series Trucks 46 07-22-2013 11:59 AM
Standard E150 van transmission fit in an F150? IDIDieselJohn 1987 - 1996 F150 & Larger F-Series Trucks 0 12-15-2010 05:04 PM
84 NP208 to 88 B-W 13-56 t-case swap? justshootme84 1978 - 1996 Big Bronco 0 08-22-2006 10:19 PM
Tags
1987, 1988, 75, blue, bronco, cab, duty, engine, floor, floors, ford, replacement, smoke, super, swap, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
