transmission crossmember
04-05-2011, 06:06 PM
on
In a '66 f-250 2wd is the transmission crossmember different from an automatic to a manual? and what year range of clutch pedal assembly and linkage would bolt up? any help would be appreciated.
04-05-2011, 06:57 PM
65 66 clutch and brake pedal hanger only. 61 to 64 is different. 67 up is different.
Trans mount is the same till 96. just needs to be moved around a bit based on what trans tail shaft you use.
Garbz
04-05-2011, 11:00 PM
Quote:
Originally Posted by
garbz2
Garbz
Garbz, I think the question was crossmember not mount....
I switched my 66 from 4 speed to auto but it's been too many years ago to answer your question, thenap1.
04-06-2011, 03:17 AM
thenap1
In a '66 f-250 2wd is the transmission crossmember different from an automatic to a manual? any help would be appreciated.
As Garbz noted "NO" same, but may have to be moved.
I swapped 3 on tree to C6 moved it a couple in. and works fine.
John
04-06-2011, 03:02 PM
on
So when switching from a cruisomatic to a four speed, i should just need to move the existing crossmember a few inches?
04-06-2011, 04:47 PM
Yes you may have to depending on the type of four speed you choose to install.
Garbz
Steve Aerostar
Aerostar
39
11-25-2016 08:08 PM
ralphhood3
12-03-2014 04:46 PM
s-man56
10-28-2012 09:37 PM
sigtauenus
04-20-2007 12:19 PM
standingstillinaz
09-16-2003 08:33 PM
1966 ,
63 ,
96 ,
99 ,
auto ,
automatic ,
bronco ,
crossmember ,
f100 ,
f150 ,
f450 ,
ford ,
transmission ,
trucks ,
v6 ,
v8
