Let's see those rattlecan paint jobs. - Ford Truck Enthusiasts Forums
Old 04-05-2011, 05:48 PM
bayley_dl's Avatar
bayley_dl bayley_dl is offline
bayley_dl is starting off with a positive reputation.
I find that rattlecans have gotten a really bad wrap. I also find that the people criticizing them are the ones who were too lazy to put the time into doing prep properly, or don't know how to spray paint evenly. Sometimes I suspect a paint/body guy because of wording and knowledge but I can't prove anything...
So, here I am saying YES rattle can your truck if it looks like crap, and you never plan on putting a $3000 paint job on it.
Important points:
Once you rattlecan you must completely remove it to paint with anything but more rattlecans. No 3K paintjobs over rattlecan, sorry.
Prep is everything, take the time to remove what you can, mask what you can't, and make sure you at LEAST scuff every square inch of what you are painting. Also, be sure to sand away flaking or oxidized paint. Then wipe it with acetone to remove impurities before you spray. I usually go with 80 grit for really bad paint and follow up with 200. Or just use the 200 to scuff. The more time you spend on prep the better your final outcome will be.
When you spray: Do it in long even horizontal strokes, depressing and releasing the nozzle for each pass. Try to keep the same distance from the body the whole time. I try for 10-12".
Some stick on pin stripe from the auto parts store will cover up any bleed over on two tones nicely.
I don't have any advice for gloss paint as I have only used flat and satin.
Don't spray flat and try to go over it with a satin clear coat. Getting even coverage is almost impossible.
If you do this right you will be amazed at what you can do for less than $100 bucks total cost and a couple days of hard work.
Anyone else with HELPFUL advice please chime in. No haters. Go park your nice clean, pretty truck in an asphalt lot somewhere for people to gawk at... ...not everyone is made of money or wants paint they are afraid to scratch.
So without further ado:
Before:
After:
and...
Before:
After:
...you're turn.
P.S. I do not recommend and would never personally spray paint over a factory paint job if there was any hope of it being brought back to life through buffing and waxing regardless of color. While rattlecans do a damn good job if done properly they don't come anywhere near factory paint for durability.
Just putting everything together.
1. Spray clear-coat is not fuel safe.
2. You can have aerosol cans filled with the paint of your choice (eg: OEM color, and fuel safe clear coat). Not sure how the durability would compare to factory but I'm curious...
3. Be sure to purchase all your paint from the same batch to ensure color uniformity. I suggest Home Depot as you can open a new box and take as much as you need.
Last edited by bayley_dl; 04-05-2011 at 09:47 PM. Reason: Adding other members advice.
Old 04-05-2011, 05:53 PM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
No pics but I done the "six pack paint job" before. I found the higher priced rattle cans do give a better paint job than those wal-fart chepo cans(but they are good for the camo jobs I've done)
Its all in how you prep and spray.
Old 04-05-2011, 05:58 PM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
I am a firm believer in prep workprepworkprepwork...And $6 per can Plast-Kote paint from Car-Quest...
-Wes
Old 04-05-2011, 06:03 PM
19fifty4 19fifty4 is offline
19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of
Great thread idea. Looking forward to seeing some more examples. The extended cab looks very good.
Old 04-05-2011, 06:19 PM
bayley_dl's Avatar
Thanks Me too.
Old 04-05-2011, 06:46 PM
1lilredwagon's Avatar
1lilredwagon 1lilredwagon is offline
1lilredwagon is starting off with a positive reputation.
Do not rattle can your vehicle. I did this number after I sand blasted my quarter and used body filler around the wheel arch. Yeah it looks beautiful in this picture but I haven't found an acrylic clear that is fuel safe or even relatively durable
Here's another, the tank on my cbr600 different brand same short lasting results
Old 04-05-2011, 06:49 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Unfortunately I'm stuck with a really cheap can paint job, done by the PO of the truck.
Doesn't look half bad in this pic, but it looks horrible now, as they sprayed a rattle can clear coat over the flat black, and the clear coat is pealing off everywhere, and so is the black, as they simply sprayed it over the original Scarlet Red paint of the truck, no sanding or anything.....
The cab was done by PO, box by me. Box is only a rough primer.
Old 04-05-2011, 06:50 PM
No pics there buddy...
-Wes
Old 04-05-2011, 06:55 PM
planehunter's Avatar
planehunter planehunter is offline
planehunter has a good reputation on FTE.planehunter has a good reputation on FTE.planehunter has a good reputation on FTE.
This is a great idea for a thread. I intend to do some second color accents this summer and I was planning to use a rattle can. I'll post pics when it gets done.
Old 04-05-2011, 06:58 PM
bayley_dl's Avatar
Thanks PlaneHunter.
1lilredwagon: Pics we could actually see would help. Put them on Photobucket and copy/paste the IMG code.
P.S. There is a preview post button...
Old 04-05-2011, 06:59 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
I agree about not using spray bombs on your truck. A MUCH better way is what the PO of my dump truck did, use a brush! The brush marks give it lots of... character. Only in West Virginia.
Old 04-05-2011, 07:03 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is online now
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
If it was a Camo job, you really did good!! I can't see a thing!!!!
Old 04-05-2011, 07:25 PM
Old 04-05-2011, 07:28 PM
bayley_dl's Avatar
Right on. I have been curious about gloss as I have only done flat and satin. Never had that problem with those.
Was it just gloss paint or did you use clear coat too?
Old 04-05-2011, 07:50 PM
That's duplicolor on the bike and rustolium on the truck I used acrylic clear on both and as I said neither is fuel resistant. Sucks because I sanded and polished everything out by hand
How to clean a Mass Air Flow (MAF) sensor - 5.4L CelticDevilDog 2004 - 2008 F150 18 11-03-2016 05:36 PM
2003 F350 Dually Cummins Conversion for sale billyrb Vehicles for Sale 1 08-08-2015 05:15 PM
Build Thread-My 1979 F100 2wd Flareside 79_effie 1973 - 1979 F-100 & Larger F-Series Trucks 51 04-24-2014 07:36 AM
Rattlecan paint job over bad rust NorthwesternCowboy Excursion - King of SUVs 4 03-03-2014 03:03 PM
New to me 05 Ex CelticDevilDog Excursion - King of SUVs 11 01-22-2014 11:16 AM
Tags
blue, classic, clear, coat, f250, ford, fuel, job, jobs, krylon, odg, paint, rattle, safe, sd, tennessee, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
