Let's see those rattlecan paint jobs.
Old 04-05-2011, 07:08 PM
bayley_dl's Avatar
bayley_dl
bayley_dl is offline
1lilredwagon: Thanks for all that. I will be trying gloss eventually and I think I will refrain from using a clear coat as pretty much every complaint I have found online has to do with rattlecan clear coat or wal-mart black... ...results and updates will of course ensue...
Old 04-05-2011, 07:23 PM
megawatt00's Avatar
megawatt00
megawatt00 is offline
Lets try and keep this civil. I have cleaned up the thread. Lets please keep it this way. Constructive criticism is one thing bashing another's idea is another. Lets please keep this on track.
Thanks!
Old 04-05-2011, 07:25 PM
1lilredwagon's Avatar
1lilredwagon
1lilredwagon is offline
Well as we all know I can not speak for the experience of others but only of my own. That being said neither of the product make any mention of their stability around petroleum products but they both claimed to be "touch up" paints. Under the assumption that a "touch up" paint would be blended with an existing painted surface which was impervious to gasoline I used two of said products with disappointing results.
Old 04-05-2011, 07:38 PM
bayley_dl's Avatar
bayley_dl
Thanks for sharing your experiences lilred. When I was first thinking of going the rattlecan route I couldn't find a decent source of info anywhere. Hopefully this thread can help people avoid others (my) past mistakes...
Jim, Thanks. Thread got a little off track there....
Old 04-05-2011, 07:40 PM
CWPottenger's Avatar
CWPottenger
CWPottenger is offline
Wow!... this is off to a rocky start....
The basic problem with "rattle-can" paint is limited nozzle patterns, a varying pressure to apply paint, limited colors, no good clears...
If you prep very well and PRACTICE, PRACTICE, PRACTICE your technique it can be done to a relative good results.
as alternative to "store" rattle-can you can go to your local paint shop and they can fill an aerosol can with what ever paint and clear you like. This is MUCH cheaper then buying all the proper gear to spay through a gun.
If you ask ANY good painter they will all tell you the key to a good paint job is prep the key to a great paint job is a TON of prep....
Personally I have seen great rattle-can results and extremely poor(these are the reason most people ASSume impossible to do right)... I have also seen Pro job that look like dog-poo so as with almost any task the person doing the job is the MOST important variable...
As an ending note a "rattle-can" jobs can turn a beat up truck into a decent looking DD for about $200-$300 which is a good deal considering a pro job runs $3000-$6000 for a 20 year old vehicle that many bought for under $2000.
Carry on....
Old 04-05-2011, 07:55 PM
1lilredwagon
Thank you CW that is probably the most useful piece of information I have read on this thread. I am sure if you go to an auto paint supply store you could achieve results like mine with the longevity of the oem paints. Just remember don't start or stop the spray without the can moving and you don't need to get complete coverage the first or even the second coat, so spray lightly and keep the can moving.
Old 04-05-2011, 08:16 PM
bayley_dl's Avatar
bayley_dl
Awesome idea with the OEM paints in a can. With some hard work, sanding, and buffing it sounds like a near original finish might be achievable for a fraction of the price. Thanks, I need to re-paint the hood on the F-250 too and wanted to stick with gloss so there is that...
Old 04-05-2011, 08:32 PM
Sarge559's Avatar
Sarge559
Sarge559 is offline
One other thing I have heard (but have no experience with) is that the same paint color from different lots can vary enough to be noticeable. This supports the idea of going to a paint store and getting multiple cans (if you need that much) custom filled for you. That way all the cans are being filled from the same "batch" and will match perfectly.
Old 04-05-2011, 08:39 PM
bayley_dl's Avatar
bayley_dl
Good call. For the regular spray cans I go to Home Depot. They have enough stock that there are always boxes full so you can open a new one and get all your paint from the same lot. Better than an Auto Parts store shelf, much cheaper too. Same paint.
Old 04-05-2011, 08:52 PM
zxwut?'s Avatar
zxwut?
zxwut? is offline
You know you can get a cheap gun from HF and do it right, easily? Might even be cheaper after all is said and done...
Old 04-05-2011, 08:56 PM
bayley_dl's Avatar
bayley_dl
My paint jobs have to be done in my apartments parking space when my neighbors aren't home... But yes I know it isn't much for an LP gun and paint. One day when I have a garage...
Old 04-05-2011, 09:01 PM
fdude64's Avatar
fdude64
fdude64 is offline
here is my hood before
  #28
Old 04-05-2011, 09:04 PM
fdude64's Avatar
fdude64
fdude64 is offline
here it is after. just wish i would have taken it off and painted the whole hood, got a bad over spray line.
  #29
Old 04-05-2011, 09:12 PM
fdude64's Avatar
fdude64
fdude64 is offline
i also painted my poor condition grill
  #30
Old 04-05-2011, 09:29 PM
akforceten's Avatar
akforceten
akforceten is offline
Before you guys rip me up cause this a 78 bronco I think this pertains to your subject matter. I'm using $2.50 krylon paint gloss royal blue well here's some pics
well there you go One rattle can paint job an yes it's all in the prep work!
Quick Reply: Let's see those rattlecan paint jobs.
