Truck shakes between 35-45mph - Ford Truck Enthusiasts Forums
Old 04-05-2011, 03:43 PM
mpjosh2001's Avatar
mpjosh2001 mpjosh2001 is offline
mpjosh2001 is starting off with a positive reputation.
My truck gets a bad vibration between 35 and 45 mph until I stomp on the accelerator and get it to kick down in gear. Any ideas on what it could be and how to fix it? I've been told it's a misfire, but wouldn't I notice it at idle too?
Old 04-06-2011, 02:52 PM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
A guess would be a bad TC clutch but no you may not notice a misfire at idle.
My 460 had a plug wire off an it idled smooth but shook under load on my last trip.
Put a KV probe on each plug wire at the rocker cover and I seen that #6 wire was off the its plug.
Old 04-06-2011, 04:39 PM
DIYiT's Avatar
DIYiT DIYiT is offline
DIYiT has a good reputation on FTE.DIYiT has a good reputation on FTE.
I'd also check the U-joints. My truck did the same thing but through the 45-55 mph range.
Old 04-06-2011, 04:58 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
There are plenty of causes for vibration. If your truck has an E4OD transmission it is well known to exhibit torque converter shudder at low speeds. A good test is to use light throttle to get the transmission into 3rd or 4th gear, just as you feel the vibration lightly tap the brake pedal. This will force the torque converter to unlock, if the vibration disappears...congratulations you have torque converter shudder.
My last '93 Lightning had it really bad when I purchased it. Once I determined it was indeed this dreaded phenomenon I could make it come and go at will with a light tap of the brake ( Or as we found out the Lightnings also release the torque converter clutch with the Hazard blinkers on).
I did a complete transmission flush and fill using a procedure I found on this site. After replacing about 18+ quarts of fluid the problem was gone. Others have used Lucas or other products, but I shy away from those if at all possible.
Old 04-06-2011, 08:11 PM
mpjosh2001's Avatar
U joints are all new. I've checked and rechecked my pug wires and the tranny guy said it wasn't TC shudder. I have an aod trans if this helps. Thanks for the replys guys. I'm still open to more ideas.
Old 04-06-2011, 09:40 PM
ravens fan's Avatar
ravens fan ravens fan is offline
ravens fan is starting off with a positive reputation.
i think i may possibly have the same thing... although mine only does it around 1000 rpm.... not sure if its the shudder or not but i do have the e4od... so thanks rla... i will try that and see if it helps
Old 04-07-2011, 11:17 AM
rla2005's Avatar
Have you checked/adjusted the TV cable? That adjustment is critical on these AOD transmissions.
Old 04-07-2011, 03:20 PM
JasonVoliva's Avatar
JasonVoliva JasonVoliva is offline
JasonVoliva is starting off with a positive reputation.
most deffinately...Mine quit after i did doughnuts in a parking lot xD
Old 04-07-2011, 03:21 PM
most deffinately...Mine quit after i did doughnuts in a parking lot xD u joints that is
Old 04-07-2011, 03:32 PM
Boss94's Avatar
Boss94 Boss94 is offline
Boss94 is starting off with a positive reputation.
My truck did the same thing at 35-45 mph. So I put on a new stabilizer on it and that fixed it. I don't know if this will help or not, because as rla said it can be a number of things.
Old 04-07-2011, 07:41 PM
ravens fan's Avatar
not to hijack the thread or anything but i tapped the brakes when mine started the shudder today as Rla said to do and ill be darned..it went away!
Old 04-07-2011, 11:20 PM
rla2005's Avatar
Quote:
Good news/bad news, eh?
Old 02-05-2014, 09:21 PM
jbird1127 jbird1127 is offline
jbird1127 is starting off with a positive reputation.
I tried the tap the breaks trick but it came right back 3 seconds after. It shakes from 35-about 50. Its been happening for About 3 months. I also notice a loss of power. I had all plugs changed and a new distributor cap. What now?
Old 02-06-2014, 07:50 AM
White Max's Avatar
White Max White Max is offline
White Max has a good reputation on FTE.White Max has a good reputation on FTE.
Quote:
I assume we're dealing with a 4R70W or E4OD here? The "tap the brakes" trick will only unlock the TC for a few seconds, after which it will go back into lockup. If you manually shift from OD into third gear, but maintain the same speed/TP, does the shudder go away? What transmission fluid are you running, and what condition is the fluid in?
Old 02-06-2014, 07:55 AM
rla2005's Avatar
The torque converter unlocks when you apply the brakes.
Your results lead me to believe that you do have the very common E4OD torque converter shudder problem. I assume you have an E4OD transmission? I highly recommend a complete transmission fluid and filter change: Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
If the problem persists you have bigger issues.
Feels like engine brake when slowing down? annaleigh 1968-2013 Full Size Vans 4 01-06-2016 09:13 PM
45-55mph shake issues bignast1 1999 to 2016 Super Duty 23 12-28-2015 09:12 AM
1992 F150 weird shaking at certain engine rpms from 35-45mph airsoft1779 1987 - 1996 F150 & Larger F-Series Trucks 0 07-30-2014 07:30 PM
Allison auto experience gandrimp Large Truck 6 08-27-2013 10:02 PM
Transmission Flush to Cure Vibration KTim 2004 - 2008 F150 7 09-05-2007 01:55 PM
Tags
1997, 35, 45, 45mph, 79, converter, e4od, edge, expedition, f150, ford, misfires, mph, shakes, shaking, torque, truck, vibrates
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
