Truck shakes between 35-45mph - Page 2 - Ford Truck Enthusiasts Forums
Old 02-06-2014, 03:48 PM
Trombogon's Avatar
Trombogon Trombogon is offline
Trombogon has a good reputation on FTE.Trombogon has a good reputation on FTE.
Quote:
Originally Posted by mpjosh2001 View Post
U joints are all new. I've checked and rechecked my pug wires and the tranny guy said it wasn't TC shudder. I have an AOD TRANS if this helps. Thanks for the replys guys. I'm still open to more ideas.
Now people can see it.
Old 02-06-2014, 03:55 PM
White Max's Avatar
White Max White Max is offline
White Max has a good reputation on FTE.White Max has a good reputation on FTE.
Quote:
Both rla2005 and myself were asking jbird1127 which transmission he/she has. The post you quoted from mpjosh2001 is nearly 3 years old.
Old 02-06-2014, 11:22 PM
Trombogon's Avatar
Ah.
I stand an idiot.
Old 02-07-2014, 02:05 PM
erupert66's Avatar
erupert66 erupert66 is offline
erupert66 is starting off with a positive reputation.
I am struggling with sorting this as EGR problem or TC problem. The shop threw in some anti-slip but no change. For me, it's when rolling into the throttle at highway cruising speeds. I've taken mine apart and cleaned it thoroughly so next I am going to try a vacuum test on my system to see if I have a leak. I'll also try this test to see if it's TC or engine, really hard to tell.
Old 02-07-2014, 07:00 PM
89danford 89danford is offline
89danford is starting off with a positive reputation.
Happened to me once when my battery terminal was loose... idk why but after i tightened them it stoped
Old 02-07-2014, 07:09 PM
eakermeld's Avatar
eakermeld eakermeld is offline
eakermeld is gaining momentum as a positive member of FTE.eakermeld is gaining momentum as a positive member of FTE.
If you have a misfire in one or more cylinders it will do this, also. A weak spark in a low RPM/rich-mid to heavy throttle condition will not fire properly. A plug can have a blazing blue spark out in the open air but put in under compression and it will fail. Coils, wires, and PIPs too. A cracked plug will do this. A cracked cap will do this.
I'm not saying the parts already replaced are bad, but who knows?
Old 05-21-2016, 01:36 AM
Steven Kennedy Steven Kennedy is offline
Steven Kennedy is starting off with a positive reputation.
My truck gets a bad vibration between 35 and 45 mph until I stomp on the accelerator and get it to kick down in gear. Any ideas on what it could be and how to fix it? I've been told it's a misfire, but wouldn't I notice it at idle too?
Could be a fuel pressure prob
45-55mph shake issues bignast1 1999 to 2016 Super Duty 23 12-28-2015 10:12 AM
Allison auto experience gandrimp Large Truck 6 08-27-2013 11:02 PM
bad vibration at 35 mph to 45 mph 97 f450 amer28 1987 - 1996 F150 & Larger F-Series Trucks 1 04-29-2011 02:53 AM
Slight bump at 35-45mph ggwash21 2004 - 2008 F150 0 07-21-2009 01:47 AM
Transmission Flush to Cure Vibration KTim 2004 - 2008 F150 7 09-05-2007 02:55 PM
Tags
1997, 35, 45, 45mph, 79, converter, e4od, edge, expedition, f150, ford, misfires, mph, shakes, shaking, torque, truck, vibrates
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
