roof to back panel seam...fill it or not?
Old 04-05-2011, 03:14 PM
71mach351's Avatar
71mach351
71mach351 is offline
Any opinions on filling the body seams like the back panel to roof seam and the seams on the upper cowl. Body filler or weld?
Old 04-05-2011, 03:50 PM
Wayne S's Avatar
Wayne S
Wayne S is offline
I welded my seams at the cowl and cab roof to cab corner but I used seam sealer in seam above rear glass.
Old 04-05-2011, 04:39 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
I think you have to weld, these cabs flex, and you WILL get a crack otherwise. you don't have to fill it completely, but a good tack every 4-6 inches at least.
Sam
Old 04-05-2011, 04:42 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
78_f800crewcab4x4 is offline
use body seam sealer, definitely no filler.
Old 04-05-2011, 05:17 PM
fatfenders56's Avatar
fatfenders56
fatfenders56 is offline
Weld it up side to side, use a Bern-Z-Omatic torch and a wire brush to remove the original seam sealer first. Finish it off for that slick-az look. LOL
Old 04-05-2011, 07:02 PM
71mach351's Avatar
71mach351
Isn't seam sealer a rubbery substance? I wouldn't think you could finish sand and paint it. What product are you refering to?
Old 04-05-2011, 08:39 PM
Randy Jack's Avatar
Randy Jack
Randy Jack is offline
I welded mine - tacks about every inch, then filled it. Looks good for a few years now.
Old 04-05-2011, 09:13 PM
jon6foot4's Avatar
jon6foot4
jon6foot4 is offline
I second this. I welded mine solid, but the first couple of welds were ugly because the fumes from the original seam sealer raised hell on the shielding gas. Once I cleaned out wiht a wire wheel and a propane torch it went smoothly. I welded the whole seam end to end, but I think Randy Jack's suggestion of tacking is probably more than sufficient. That won't flex...
Old 04-05-2011, 09:23 PM
CharlieLed's Avatar
CharlieLed
CharlieLed is online now
Seam sealer comes in various forms...the one you want is one of those that is a 2-part product. I use a 3M sealer, 2-part, that sets up in less than 10 minutes and has a consistency of a hockey puck when cured. This product can be sanded and painted...the only issue I have with it is that the expansion rate is different than the paint so I always leave a little space on top of the sealer to add a thin coat of body filler to finish off the repair.
Last chance 53
10-10-2016 09:33 AM
1966f100ranger
08-20-2016 07:27 PM
Kurt G.
50
01-18-2016 01:26 PM
hppydrunk
05-03-2007 12:36 AM
Earl
18
09-13-2005 07:41 AM
Quick Reply: roof to back panel seam...fill it or not?
