1994 Solid Axle Swap (Dana 44)
theres no way you will convince me( or most people) that d44 can be built stronger then a 60 for reasonable cost. You will come out cheaper in the end just buying a 60. Even after you do your axleshafts and knuckles and what not, the spider gears in them might as well be plastic. I broke them with 33s and 35s.
Also broke a ring and pinion on 35s. All this with stock motor.
Thats what i am thinking.
But its cool to see something different i guess. Its just that the outers aint the Only problem. The gears are what i get trouble out of. Spider gears and the ring and pinion. But i hope it turns out good for you. If it works for you then you gave everyone else on here a nice alternative.
Jonathan McManus
11-27-2016 08:19 PM
Mud&Snow
05-30-2012 07:55 AM
.87-ford
01-15-2012 06:58 AM
jackdaniels250
05-03-2011 04:33 PM
