fuel tank
fuel tank
Dear FTE members,
I came across a dilema today. My mechanic purchased a gas tank from the junk yard today and lo and behold it did not fit under the truck. I am trying to fit it underneath the frame in the back of the truck, I have a 1956 ford pickup. my dilema is he is charging me by the hour and I dont think he knows what to look for and so I need someone's expertise. What is a recommended gas tank for this type of truck. What will fit underneath it. I am on a budget and can not afford a alum. fuel cell. So any help you can offer will be greatly appreciated.
An aluminum gas tank is less than $400, and I'll bet you've already spent nearly that much paying your mechanic to goof off at the junk yard and buying some rust filled tank that doesn't fit, so he has to do it all over again. What will that cost? If you have the ability to do things yourself, there's a lot of labor intensive shortcuts you can take. But at $50 an hour, or more, how much are you willing to spend on his time to hack in junk, when a made-for-your-application tank will fit in place by drilling 4 holes. Time involved, 30 minutes. If you have an electric drill, you could perhaps even do it yourself.
So there's your choice, parts or labor. It's the same money, where do you want to spend it? On nice, new parts that will add value to your project, or into your mechanic's pocket? I can appreciate being on a budget as well as anyone. But there are times where trying to save a buck costs way more than it's worth.
This is what I put in my 1960. You can call and check the dimensions and see. Many other tanks available at this vendor and they are not full of rust.
Discount Radiators - # 1 source for all radiators online - all makes amd models - best price!
BigBlockF-250
05-03-2003 11:04 PM
