Gas Tank Down - HOW To Remove Wires??? - Ford Truck Enthusiasts Forums
Old 04-04-2011, 02:54 PM
RocketmanVT's Avatar
RocketmanVT RocketmanVT is offline
RocketmanVT is starting off with a positive reputation.
Question Gas Tank Down - HOW To Remove Wires???
1992 F-150, 302 CID, 2-Wheel drive:
I've dropped the front/amidship gas tank to get at the float valve, and I can't find the disconnect point for the wires leading to the fuel pump. AND, I need to remove the fuel lines - can that be done AT THE TANK ITSELF?
1. WHERE do I disconnect the wires?
2. Can I remove the fuel lines AT THE TANK ITSELF? I have already relieved the fuel pressure.
Thanks in advance.
Old 04-04-2011, 04:06 PM
Hotshot869's Avatar
Hotshot869 Hotshot869 is offline
Hotshot869 is starting off with a positive reputation.
I had to replace my front fuel pump a while back so i can't cite step by step, but i'm fairly sure with that special tool(cause Ford loves being difficult at times) you can remove the lines at the pump, same with the wires. You should be able to just disconnect, and go. Correct me if i'm wrong anyone.
Old 04-04-2011, 06:45 PM
Blue Rebel's Avatar
Blue Rebel Blue Rebel is offline
Blue Rebel has a good reputation on FTE.Blue Rebel has a good reputation on FTE.
Yes, lines and wiring are removed at the pump. The 4 wires go into 1 plug. Pull it up away from the pump.
The lines also disconnect, but you do need the special disconnect tool. Theyre pretty cheap, like 10 bucks at any auto parts store.
Old 04-05-2011, 04:12 PM
I've got that special tool - the one that 'scissors' at the center, with 3/8" and 5/16" cup-like ends that go inside the fuel-line fittings - and it has not released the fittings. I used it on the fuel-filter fittings, but it has proved useless at the tank.
Is there another tool to unlock the fittings?
Old 04-05-2011, 04:23 PM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
Posting Legend
dustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputation
what year is the truck? 85-89 have a clip that needs to be removed with a screwdriver. 90 up, put in the tool, and push, then push in on the line, and pull the line back, the clips are probably stuck.
Old 04-05-2011, 04:31 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
I had a devil of a time with one of the fuel lines releasing on my '92 F350 when I changed the rear tank. I had the fancy metal fuel line release tools, none of them worked. I tried spraying WD-40, PB Blaster, etc. no worky. The other line came off with no problems.
I ended up buying a cheap set of plastic release tools, slid the correct size into that pesky connector, pushed/pulled for 2 seconds then all was good with the world again.
'86 f350 Fuel Delivery Stumper - Any help would be greatly appreciated xavier9480 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 08-21-2015 10:38 PM
Tips for disconnecting 5/16 fuel line from tank? natedog37 1999 - 2003 7.3L Power Stroke Diesel 6 07-26-2015 11:49 AM
Dropping the fuel tanks UPDATE B Big 1994.5 - 1997 7.3L Power Stroke Diesel 1 02-03-2014 09:25 AM
Undercoating help FordYoungGun35 1987 - 1996 F150 & Larger F-Series Trucks 38 10-30-2013 02:35 PM
Fuel Line disconnect rockfoot 1987 - 1996 F150 & Larger F-Series Trucks 14 11-20-2009 06:52 PM
Tags
1997, 2001, 97, aerostar, f150, f250, f350, ford, fuel, gas, lines, remove, removing, tank, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
