99-04 super duty leaf spring lift in 71 f250 - Page 24 - Ford Truck Enthusiasts Forums
  #346
Old 05-19-2014, 05:20 PM
highntight's Avatar
highntight highntight is offline
highntight has a great reputation on FTE.highntight has a great reputation on FTE.highntight has a great reputation on FTE.highntight has a great reputation on FTE.highntight has a great reputation on FTE.
THAT LOOKS GOOD SIR.... WHAT DID YOUR EYE TO EYE END UP BEING ON THE FRONT CROSS TO THE REAR SHACKLE MOUNT ????
  #347
Old 05-19-2014, 11:07 PM
grinnergetter's Avatar
grinnergetter grinnergetter is offline
grinnergetter has a good reputation on FTE.grinnergetter has a good reputation on FTE.
For the tall hangers you could use dent 2wd F250 which are 3"...worked for me.
  #348
Old 05-20-2014, 11:00 AM
crazed87bronco's Avatar
crazed87bronco crazed87bronco is offline
crazed87bronco is gaining momentum as a positive member of FTE.
Quote:
Turned out nice still need to add a plate on the outside of the frame rail wrapping down around the hole for the eye of the spring. and some inside braces to go from top of frame rail to the crossmember to keep from folding in the rails. Distance from x member to shackle mount eye to eye is 53 7/16" real close to the stock 53 1/2" leaf springs still got to settle anyways so it should be good.
  #349
Old 05-20-2014, 11:33 AM
Quote:
Thanks for the suggestion I'll have to look into them more. These Chevy hangers in pics below would probably be perfect but can't find any with true 3" wide springs so my leafs won't fit in them. What's the distance from the bottom of the frame rail to center of the leaf spring hole on those dent side long hangers? Got any pics you can show me it'd help me out a lot.
  #350
Old 05-28-2014, 02:55 PM
Got my hydroboost setup all mounted and pedal linkage done. That master cylinder sticks out pretty far in the engine bay but still have almost 2" clearance from the fuel shutoff solenoid. Been messing with the clutch mounting some just trying to get the hole in the firewall right the first time. Hardest part is getting the right pivot point.
Hydroboost linkage modification
  #351
Old 05-28-2014, 08:16 PM
  #352
Old 05-28-2014, 09:15 PM
Do you know the measurement from center of bolt that goes through leaf spring to the bottom of frame rail with that hanger your using?
  #353
Old 05-28-2014, 09:31 PM
Hang on................................................ ............................................
.................................................. .................................................. .........................2.00 give or take a smidge.
  #354
Old 05-29-2014, 11:29 PM
Interesting, that picture of the hanger makes it look like it's further down then 2" from the frame. I'll have to measure mine again but I think the super duty leaf spring hangers I'm using are around 2" below the frame. Here's a bad pic of current setup. The long chevies look like they'd be perfect but they are only for a 2.5" spring
  #355
Old 06-12-2014, 09:46 AM
Back to work on the crew for alittle. Haven't got much time lately on it. But I have put time in on the old lady's 79 4x4 removed rear gas tank between frame rails and wet blasted the frame and all suspension parts from cab back with the bed removed. First time I used the pressure washer and abrasive sand technique. Does a decent job and less dust and residue left behind but can't reuse the abrasive and some areas seems like a dry sandblast would clean up the frame better. Anyways I got my clutch hydraulics mounted to the firewall still need to pull the engine one last time to finish cross members, clean paint reseal engine and put clutch in trans. Then I can mess with the clutch pedal to push rod throw that's always the fun part.
After tightening the brake booster and clutch hydros up the clearances got alittle tight between the 2 only about 3/8" might be able to shorten the soft hydroboost line to gain another 1/4" for peace of mind no touching.
  #356
Old 06-12-2014, 01:31 PM
Tinstar36 Tinstar36 is offline
Tinstar36 is starting off with a positive reputation.
Man I am glad you posted those pictures I don't know where to put my clutch master.
  #357
Old 06-12-2014, 09:07 PM
I got some measurements off a stock dodge clutch pedal swing and pushrod travel then messed with my pedal swing measuring until I found a suitable pivot place to allow enough travel hopefully.... Then made some cuts. Just wish my clutch was in so I could see if it releases good and pedal travel ain't funky. Picked up a intake horn cheap so I messed with that today and did some yard work. I'll post pics when I get the chance.
  #358
Old 06-13-2014, 01:06 PM
This should help it breath alittle easier. Also cleans up the engine bay and has 2 1/8" NPT ports for a boost gauge and water meth injection when I get that far It will be powder coated probably candy purple once I get a big enough pile of parts together to run to the coaters. I Don't like the oil dipstick location so the tab will be cut off on the intake and mounted somewhere else.
Let's compare here's the stock 12v intake
New one
Old one
Any difference?
And installed take notice to oil dipstick location
  #359
Old 06-13-2014, 08:40 PM
Nice and smooth....I think it looks good red.
  #360
Old 06-17-2014, 10:05 AM
highntight's Avatar
!0-4 X2 on the red.... What brand is your new intake elbow....
78-79 Dana 60 kingpin, supercab frame, 78 complete truck for parts crazed87bronco Ford Truck Parts for Sale 24 02-10-2017 03:02 PM
1967 F100 project crazed87bronco Vehicles for Sale 1 10-30-2016 10:27 PM
1971 Ford F250 Camper Special crazed87bronco Vehicles for Sale 0 06-29-2016 01:26 PM
1978 Ford F250 4x4 snow fighter crazed87bronco Vehicles for Sale 0 06-25-2016 06:07 PM
1973-79 supercab exterior trim crazed87bronco Ford Truck Parts for Sale 3 04-05-2016 11:03 PM
Tags
2, 2000, 71, 99, 9904, duty, f250, leaf, lift, rear, spec, spring, springs, super, superduty, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
