99-04 super duty leaf spring lift in 71 f250
#196
ya i hope so to i dont see why it wouldnt. the guy i talked to that runs the first gen ic and rad has done a couple pulls and he said stayed plenty cool. he was happy. good call on the mechanical fan. im running electric on the yoda and hate them thats the only thing ive had problems with. ya get some pics of finished product lookin great. picked up that ic. i was going to ask you could you not leave the top mounts where they were its been so long since ive had the front end together i dont remember. but from pics ive looked at seems like you almost could?
#197
And for some progress pics got the lower part of the support that I cut out all played back in wanted to finish it today as they are calling for rain the next couple days got it all cleaned up and ran out of grinding discs just need a tiny bit of smoothing yet started to rain right as I ran out of discs so perfect timing the weather held off just long enough ready for paint as soon as I get a disk and only will take about a minute for the smoothing out part
#199
Ok back to work Alil bit I been slacking once again and haven't touched frankenford in over a week been working on the challenger and going to car shows lately had the challenger out for the first time this year (been addicted to my cummins) over the weekend oh BTW I'm selling my challenger and my bike if anyone is interested. But back to the crew cab got the Ic mounted and radiator still deciding how I want to make the top radiator hold down so any ideas are welcome so while I figure that out I started mocking up all the Ic and rad plumbing. Just need to order all the right boots I used what I had laying around just to give me a idea what I need. Only thing I got to figure out is the lower radiator hose to water pump cut the stock dodge one up but not quite the right bends needed so I may try looking for something close at the parts store or try making my own pipe. Here's some pics
Top radiator hose perfect fit
Was thinking of ideas for my top radiator mount as you see the bolt would be a piece of pipe instead and it would unbolt from radiator support any ideas welcome still deciding
Lower radiator hose not liking the bends need better solution
Cold side Ic pipe
Cold side Ic pipe
#200
#202
It's a long process as I keep going back and changing things I'm on my 5th rear axle and 3rd front axle thinking about going with a Aam front axle now with a 4 link and coils but we will see. a dual disc valair clutch is next on my list to get so I will be one step closer to firing it up. I've been following your build to haven't seen any updates lately. Ryan any ideas on how to make my top radiator hold down? I've been racking my brain for the past week on it. Decided to do the plumbing and today I finished trimming my grille fitment need to take pics of that as another member is curious of the clearances. Still need to trim the grille inserts might do that today.
#203
I think you have figured out your upper rad mounts on your own. I like what your doin there. You could even run a 2" strap from your piece that sits in there and shoots straight over to your rad support where you could ether weld to flange that bolts to support or bend your strap 90 degrees and bolt that way. I think your radiator is going to be plenty looking at it. what exact radiator are you running. Part number? Is it a 3 or 4 core? Where did you get it? How much? Ha ha...... Your hard core now your thinking 4 link up front. Not a bad idea for what your doing, its just funny your thinking about changing again. You could 4 link your 60 as well if you wanted. I like the turbo idea but make sure you get a down pipe with it there stupid special flanges are expensive and hard to find. Its easier to find someones stock down pipe. I'm not sure but aren't the second gen turbos clockable. P>S> I find myself staring at the pic with your gill on where your ic is centered in it. Looks bad a$$.
#204
#205
#206
Made some progress last week got the grille and inserts trimmed and fit up lucky I still had something left of the inserts. I'm thinking about putting some kind of screen mesh behind the inserts to help with any sticks and whatnot from poking the IC and give it Alittle more appearance look. Tell me what you's think. one insert is silver as the other is black because the original one on the truck was cracked and truck came with the black one for a replacement. Only worked on it for about an hour over the weekend got my throttle cable mounted from the engine and secured through the firewall all i need to do now is mess with the cable to pedal attachment. just wasn't motivated to be outside in the direct sunlight when its hot enough out to sweat in the shade just standing there.
Also did Alittle stone guard fitment looks like a good portion will need trimmed off of it to fit between the bottom of IC and radiator support
#207
man that looks great. funny how your grill is perfect but the hood is so hammered. but how your ic sits in there looks tuff.. i think im going to paint my grill same color as the truck and polish the crap out of the ic so it stands if it sits anything like yours does. have you seen the billet inserts for your grill. there spendy but look so good. any ideas on hood latch or is that out ya think? im not sure on the second gens really have never played with them. im going with the 3rd gen turbo. found down pipes that are 5 inch on ebay for 120.00 so not terrible. then modify from there. i had a phatshaft 62 on my 3rd gen and it spooled quick. i think with the cam im runnin im going to go with the super phatshaft 64 or the silver bullet 64 or 62. the guys at industrial infection are really actually pretty smart and its worth a call to them tell them what you got and what the plan is and if you can get someone that not just trying to sell you somethin and willing to listen could be a useful call. when you bought yours radiator do you remember if they offered a 4 core? also whats the big pipe for in the last couple picks. ive seen a few people cut the part of the fuel linkage that goes out side the fire wall off and weld it on the inside and run a stock dodge cable. drill a round hole and file it square and fits like a charm. how did you do yours?
#208
Yea it sucks this truck is in this bad of shape from rust I've already patched the dreaded roof rot but will need to remove the drip rail to get the small holes yet not looking forward to that at all. The grille is in good shape except for one headlight bezel is scuffed from something? I got big plans for the grille and IC I can tell you that it will be wicked and be one of a kind for sure. I will be polishing the IC as well but ill let the grille be a nice s*** in your pants moment hahaha I've seen them billet grilles and was going to get one but wasn't sure if it would of fit with my IC so I passed on that. No idea on the hood latch yet ill need to mount my other hood on the truck to see if anything will work this hood is to banged up and has no latch on it to find out. What made you decide on a 3rd gen turbo? I got to call around and see what II says along with E.D about turbo setups the silver bullets sound like they are good turbos from what I've read and others said about them but I see them way to much for sale makes me wonder if they are so good why do I see them for sale and the owners saying going a different turbo route. I'd like a 64mm but don't know how it will be for trail riding. I can't say if they offered a 4 core or not I'd imagine it would need custom made I just browsed websites and checked out radiators that fit my measurements had the ports on the right sides and right size in/out ports forgot to get the part number for you ill try to remember to get it for you. That big pipe is for u joint shields to go around the axle yokes sounds like the throttle setup your talking about is almost how I'm doing mine do you have any links to the throttle setup your talking about? Ill have pics up hopefully by end of the week with the finished cable setup
#209
Also forgot another picture update from last week one day it was raining out and I wanted to get something done so I finally got around to rebuilding my steering column only been 2 years since I went and sent it to be powder coated in that time ive been pondering getting a tilt column from a dentside truck so i prolly wont even use this one now. so I sat down in my living room on the couch and started assembling it and heard a rustling sound behind me turn around to look and what do you think I seen? Scroll through the pics and you shall see what happens when I get spooked and a trusty burner close by
Parts laid out
Lower bearing and NOS retainer installed
Upper bearing retainer and switch installed
And the damn spooker I showed him
Parts laid out
#210
wow what the hell.... thats creepy.... what kind of snake is it. that commin down there for them to get in your place? steering column looks great. that sucks your not going to use it. i like the 74mm turbine wheel and the 14cm housing. no worries. i think im going to order the 4 core ford radiator and have my buddy switch the necks for me. for easy bolt in....
