92 f150 codes
That code 11 is not really a code, that is a System Pass.
The other codes 31 and 34 are related to the EVP signal when the EGR is supposed to be closed. Code 33 indicates the PCM is not sensing any EGR movement at all.
I would start by checking the EVP output signal. See what it is with the valve closed, then apply some vacuum to the EGR and watch the output signal.Verify if it jumps around a lot. That indicates the EVP sensor is probably faulty.
As far as Code 33, check the EVR it may be bad or someone has disconnected the vacuum source to the EGR valve circuit.
For reference:
Ford Fuel Injection » EGR Valve Position sensor (EVP)
Ford Fuel Injection » EGR Vacuum Regulator (EVR)
For reference:
WhatsAChevy?
12-28-2015 11:22 PM
Farmboypowerstroke
10-29-2011 05:05 PM
LiftdFord
21
08-18-2009 01:26 PM
