2008 f250, no trailer lights but brakes work
I hooked up a buddy's trailer that had been in a field during a brush fire. It sustained minimal damage but some of the wiring got melted. Well now my trailer light plug has no power for any lights. The brakes work fine but no lights, not running, braking, or signals and there is no power at the plug for lights. I assumed fuse, but checked the ones that I thought they could be and they were fine.
I would assume the trailer lights shorted out and blew a fuse but I checked all of them with a test light and didn't find any blown. Any relays?
Possibly, but wouldnt that affect the trailer brakes also? With a test light at the plug, there is 0 power except on the brake pin when brakes are applied.
Any idea what fuses for sure control the trailer lights? I checked all of the fuses in the.kickpanel and all the ones I thought could be right under the.hood
this manual (online copy) http://www.motorcraftservice.com
at page 300
lists all the fuses.
note there is a lamp RELAY too..
Sam
at page 300
Sam
did you actually check in the wiring harness BEFORE the bed plug connection?
Sam
understood.. no power at the plugs.. fuses seem good.. check the relays.. I think there is one you can swap.. maybe the brake relay for the light relay.
then check the connection for the bed plug..
Sam
Sam
relay 42 is trailer park lamp relay, 44 is the trailer battery charge relay
Sam
fordtrkpuller
03-15-2021 06:35 PM
Old93junk
07-04-2017 09:07 PM
