2008 f250, no trailer lights but brakes work - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 04-03-2011, 10:12 PM
2kcrewcab 2kcrewcab is offline
2kcrewcab is starting off with a positive reputation.
I hooked up a buddy's trailer that had been in a field during a brush fire. It sustained minimal damage but some of the wiring got melted. Well now my trailer light plug has no power for any lights. The brakes work fine but no lights, not running, braking, or signals and there is no power at the plug for lights. I assumed fuse, but checked the ones that I thought they could be and they were fine.
I would assume the trailer lights shorted out and blew a fuse but I checked all of them with a test light and didn't find any blown. Any relays?
Old 04-04-2011, 10:15 AM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
there ARE two sets of fuses.. one in the right kick panel area too.. altho I haven't seen those blow out..
is there a bad ground at the trailer plug?
Sam
Old 04-04-2011, 10:26 AM
Possibly, but wouldnt that affect the trailer brakes also? With a test light at the plug, there is 0 power except on the brake pin when brakes are applied.
Any idea what fuses for sure control the trailer lights? I checked all of the fuses in the.kickpanel and all the ones I thought could be right under the.hood
Old 04-04-2011, 10:30 AM
sdetweil's Avatar
this manual (online copy) http://www.motorcraftservice.com
at page 300
lists all the fuses.
note there is a lamp RELAY too..
Sam
Old 04-04-2011, 11:05 AM
Thanks, ill take a look when I get home.
Old 04-04-2011, 11:10 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I would also suggest hooking up to a known good trailer as an easy method to check your truck and fuses.
Old 04-04-2011, 11:18 AM
Ya, I did use 2 separate trailers and both the bumper plug and the bed plug. Both have the same issues. Both trailers the brakes worked and.both pkugs had no lights
Old 04-04-2011, 11:32 AM
sdetweil's Avatar
Quote:
wait.. new news.. BED plug..
did you actually check in the wiring harness BEFORE the bed plug connection?
Sam
Old 04-04-2011, 11:36 AM
Both plugs worked a month or so ago before I hooked his trailer up.
Old 04-04-2011, 11:38 AM
sdetweil's Avatar
understood.. no power at the plugs.. fuses seem good.. check the relays.. I think there is one you can swap.. maybe the brake relay for the light relay.
then check the connection for the bed plug..
Sam
Old 04-06-2011, 04:11 PM
ok, so I am JUST getting to troubleshooting this. Sam, i tried clicking on your link above and it says i do not have permission to the site and need to login again?
Does anybody know which relay is the lamp relay?
Old 04-06-2011, 04:19 PM
sdetweil's Avatar
gr.. I hate that site.. I fixed the link.. then u have to pick guides in the left nav, and ...
relay 42 is trailer park lamp relay, 44 is the trailer battery charge relay
Sam
Old 04-06-2011, 04:23 PM
Thanks, heading out now to check it out!
Old 04-07-2011, 07:04 AM
Larry NCKS's Avatar
Larry NCKS Larry NCKS is offline
Larry NCKS is starting off with a positive reputation.
Where's your owner's manual? It would have all information about fuses, relays and breakers.
Trailer connector-no brakes or turn signals RUSTANG67 2009 - 2014 F150 4 07-18-2015 08:25 PM
Trailer lights not working please help!!!! jdhudall 1997 - 2003 F150 10 04-02-2012 12:13 AM
Help on trailer lights... makomaker 1999 - 2003 7.3L Power Stroke Diesel 21 04-03-2010 04:22 PM
Help with trailer plug.... makomaker Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 23 02-24-2010 10:23 AM
Testing the trailer plug preppypyro 1999 - 2003 7.3L Power Stroke Diesel 22 04-02-2009 02:46 PM
Tags
1996, 1997, 2000, 2008, 2009, brake, excursion, f150, f250, ford, light, lights, pickup, power, trailer, truck, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
