ECM for 1988 F150 302 Auto OD Trans
Old 04-03-2011, 08:12 PM
peterso's Avatar
peterso
peterso is offline
I have a 1988 F150 with calibration code 7-54J-R11. The ECM in the truck now is a E8TF-12A650-F2A but no local parts store has one. I bought the truck usted in 1997 so I don't have any way to be sure that this is the ECM that origionally came in the truck. Can the correct ECM be determined using the calibration #? The truck has a 302 with 4 speed automatic. Some strores say that maybe a E8TF-FA ECM will work. None of them recognize the long number. There is also a 8PV in large letters on the label of the current ECM and on the back of the unit.
Old 04-03-2011, 09:17 PM
babarche's Avatar
babarche
babarche is offline
PCM identification - Crownvic.net
Looks like the one you have is probably original. There is one on ebay that matches.
1987-89 F150 BRONCO ECU 5.0L E8TF-12A650-F2A 8PV AT - eBay (item 130480206516 end time Apr-27-11 22:17:42 PDT)
There is a user on here named "dro man" who can look up the part number by calibration number, see this thread: https://www.ford-trucks.com/forums/1...ification.html
Try sending him a PM.
Old 04-04-2011, 07:18 AM
subford's Avatar
subford
subford is offline
The Ford part numbers for your computer are E7TZ-12A650-AUB and E8TZ-12A650-FA.
But this is not the number on the computer as only Ford dealers parts department goes by the part number.
The drawing number that is on the unit would be E7TF-12A650-AUB and E8TF-12A650-FA.
Most drop the base part number of 12A650 as all Ford computers have the base number in them.
So you are looking for a computer at an auto part store or on line with a number of E7TF-AUB or a E8TF-FA.
At a salvage yard a E7TF-12A650-AUB or a E8TF-12A650-FA as they go by the number on the unit.
Here is your parts list.
The following users liked this post:
Old 04-04-2011, 09:49 AM
peterso's Avatar
peterso
peterso is offline
Thank you very much
subford and babarche
Thank you very much this is just what I need!
Owen
Old 04-05-2011, 11:34 PM
babarche's Avatar
babarche
babarche is offline
No problem, hope you get it fixed, I noticed your older thread. Let us know how it works out!
Old 05-21-2013, 02:23 PM
429martin's Avatar
429martin
429martin is offline
1988 Bronco will not start sometimes
Anybody out there have any idea what the problem might be with this Bronco? I am thinking of buying it as a second vehicle. Thanks.
</FIGURE><SECTION id=ecxpostingbody>We purchased this Bronco about 6 months ago. It is a super sweet vintage ride with a custom paint job from the 80s. The back window rolls down for perfect beach or camping trips!!
When we bought it, the owner told us that once every six months or so, the truck wouldn't start. Leave it for 10 minutes, try it again and it starts right up. Well it happens more often than once every six months. We have had it in the shop for a month and our mechanic has no clue whats wrong with it. He can't find a problem. The last owner had the engine replaced, so it may have something to do with that. This needs to go to a Bronco lover that has the time for a project. We just don't have time to deal with it.
Old 05-21-2013, 03:27 PM
subford's Avatar
subford
subford is offline
More than likely it has a bad computer.
But could also be the PIP sensor or the ICM.
Old 05-21-2013, 03:56 PM
429martin's Avatar
429martin
I appreciate that and my bro-in-law said it could be the electronic control module, Thanks for the reply.
Old 05-25-2021, 06:33 PM
Chris96f250's Avatar
Chris96f250
Chris96f250 is offline
Ecu
this a Old post...... My 88 Ford f150 4x4 has missing ecu as
it is gone from vehicle, I put a van ecu in it and starts but idles rough, has Calibration Code 7-54J-R11 aswell So Above pcms what I need? Any way have a list all that will work? Thanks.
Old 05-25-2021, 08:18 PM
subford's Avatar
subford
subford is offline
The above information is what I list.
Here is the listing:
Old 05-25-2021, 10:05 PM
Chris96f250
[QUOTE=subford;19898439]The above information is what I list.
Thank You, Helped me a Bunch, Now I Know what to Look for at a Salvage Yard. 🍻
Old 05-26-2021, 04:15 AM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is offline
Received 1,358 Likes on 1,073 Posts
It is about $60 dollars for a used PCM from the junkyard if you buy the 90 day warranty. For another $40 you could have a reman computer with a 1 year warranty. Yes it cost more but if the truck wasn’t wrecked why is it in the junkyard? More than once I have seen a vehicle in the junkyard with a bunch of new new engine sensors.
Old 05-26-2021, 06:30 AM
torq'ta 5 8's Avatar
torq'ta 5 8
torq'ta 5 8 is offline
What motor, trans in your truck? The Calibration code you gave, is that from your truck, found on driver door jamb? or is that from the van? you need the calibration code from your truck.
Cannondale372
51
07-07-2023 11:59 AM
cforssi
13
11-19-2017 05:26 PM
mattmattf14
05-01-2017 10:22 PM
GuitarJesus
10-21-2014 05:22 PM
95_EOF_f150
10-22-2012 07:34 PM
Quick Reply: ECM for 1988 F150 302 Auto OD Trans
