Distributor curve question - Ford Truck Enthusiasts Forums
Old 04-03-2011, 04:14 PM
rustywheel68 rustywheel68 is offline
rustywheel68 is starting off with a positive reputation.
The vehicle- street-cruiser Galaxie 500, with a stock 390/auto.
I've been gearing up for a distributor recurve, and finally got into it this weekend. Before I took it apart, I took a baseline reading (using a tach and an assistant on the gas pedal). Its not the most accurate method, but its the best I've got.
Baseline:
Initial: 10 degrees
1000rpm - 10
1500rpm - 21
2000rpm - 26
2500rpm - 28
3000rpm - 30
Then, I took it apart. Its got stock-looking springs- one heavy, one light. The slots are "10L" and "15L". the arm is currently using the 10L slot, and there is a little rubber bushing around the arm, which i guess is limiting it to 8-9 degrees, instead of the full 10.
Since I was running 10 initial and its using the 10L slot, it appears that I'm all in at 3000 rpm, which was surprising, since its got a heavy spring.
So- I'm looking for advice on which way to go at this point.
I suppose I could leave everything alone, and just try to run 18 degrees initial...or I could switch to the 15L arm and then back off to 8 initial.
Thoughts? Should I even bother with changing the springs? I've got the Mr Gasket 925D on hand.
Thanks-
Old 04-03-2011, 04:57 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust Ziegelsteinfaust is offline
Ziegelsteinfaust is starting off with a positive reputation.
For my mild cam/low compression D-Chamber or old school wedge chambers I like 14* initial, and 36* max total.
I would advance the timing, and try lighter springs. The experts say you want full advance by 2500 rpm, and some low compression motors can take it all by 2000 rpm.
Its a game and I would try a few combos to get what is right for you car. Atleast Ford put the dizzy up front. Right???
Old 04-04-2011, 08:56 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
I think that "10" is WITH the rubber bushing. It's supposed to be there.
As long as you have a "stock" cam, and you get enough vacuum at idle at 8 degrees to run the carb on the idle circuits, I'd go for the 15 slot and see what happens.
Old 04-04-2011, 02:19 PM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.
Just bump you initial to 16 to 18, that will give you a 36 to 38 total mechanic advance which will maximize your performance. This will also help mpg.
Old 04-04-2011, 02:22 PM
Krewat's Avatar
At 16-18, he's running the hairy edge of the starter not turning the motor over fast enough when it's hot, is he not?
Old 04-04-2011, 02:32 PM
Bear 45/70's Avatar
Quote:
I never had this issue with any of my 428s or 390s running 18 initial. I had to get in the 20+ of initial to encounter kick back.
Old 04-05-2011, 09:47 PM
I figured I'd start with the easiest option first- I've bumped the initial to 15. So far, so good. The car is happier, for sure. I'll drive it a bit, and may try to get it up to 16-18 over the weekend.
thanks-
1970 Distributor build and curve-390 Classicdriver 1967 - 1972 F-100 & Larger F-Series Trucks 18 02-14-2017 03:57 PM
Pinging in 400 no matter what i do smith1978 1973 - 1979 F-100 & Larger F-Series Trucks 30 05-27-2015 02:26 PM
Holley 4160 on 351M - help please!!! NMFirstF2504X4 1973 - 1979 F-100 & Larger F-Series Trucks 45 03-14-2014 08:02 PM
390 knock when cruising LCPullman FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 17 01-11-2010 01:34 PM
Distributor advance & timing curve tbm3fan 1961 - 1966 F-100 & Larger F-Series Trucks 1 03-04-2007 08:01 PM
Tags
390, curve, distributor, fe, ford, recurve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
