VERY slow and noisy Windshield wipers! - Ford Truck Enthusiasts Forums
Old 04-03-2011, 03:14 PM
Claybe Claybe is offline
Claybe is starting off with a positive reputation.
I have a 1992 F250 4x4 and the wipers are REALLY slow. Even on the fastest setting they seem like they are on low. All the speeds work and the intermittent speeds work too, but it takes at least 3 seconds for them to make one swipe. I did a search and saw something about cleaning the switch on the turn signal, but didn't know if the motor was bad? It is also making the clicking noise under the passenger's side dash board. Thanks for any help!
Old 04-03-2011, 04:14 PM
rikard rikard is offline
rikard is gaining momentum as a positive member of FTE.
The module is located on the pass side and you should only hear clicking in the intermittent settings. Check the voltage at the motor and any ground wires in the area.
regards
rikard
Old 04-03-2011, 05:56 PM
Thanks for the reply! That is correct, there is only "clicking" on the intermittent settings. I took the turn signal a part and cleaned it out and that seemed to help a little bit, but it still seems slow. Maybe things were just slower back then?
Old 04-03-2011, 07:32 PM
octaneforce's Avatar
octaneforce octaneforce is offline
octaneforce is starting off with a positive reputation.
my 92 f150 can get the wipers moving pretty fast. something must be wrong. rikard has the right idea to start
Old 04-04-2011, 12:43 AM
cj06's Avatar
cj06 cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
check the wiper linkage under the cowl and see if any thing is broke or bushings missing !
Old 04-04-2011, 12:10 PM
ChristopherN ChristopherN is offline
ChristopherN is starting off with a positive reputation.
It's probably the wiper motor going out. My brother's 94 bronco, and my truck's motor was crapping out. I think they're about $30 bucks for a new one from CarQuest.
They're not *too* hard to replace. I had to take my hood off to get the vent along the bottom edge of the window so you can get to all the bolts.
You need to make sure you get the right one, some motors have two plugs and some have one plug.
Windshield wiper relay 86 Bronco II dledm Bronco II 3 05-25-2016 09:27 PM
79' 2 speed wiper motor issues Corpsman24 1973 - 1979 F-100 & Larger F-Series Trucks 7 08-22-2014 11:01 AM
Wiper Motor Noise lasmacgod 1999 to 2016 Super Duty 1 08-12-2010 09:37 PM
intermittent windshield wiper not working correctly mjorg 1987 - 1996 F150 & Larger F-Series Trucks 3 09-27-2009 11:51 AM
Wipers Not Working Properly mattd860 1987 - 1996 F150 & Larger F-Series Trucks 13 05-30-2009 07:21 AM
Tags
05, 1992, 1994, clicking, f150, ford, make, moving, noise, noisy, slow, truck, windshield, wipers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
