Can't fill gas tank, pleading for help. - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-03-2011, 12:13 PM
BolognaBlake BolognaBlake is offline
BolognaBlake is starting off with a positive reputation.
1999 F250 V10 4x4 Ex. Cab and 8ft. bed.
It takes about 5-6 minutes per gallon, if that. And that's only at stations that can pump that slow. So, basicly, the truck isn't getting driven.
Cleaned the canister. Wouldn't fill. Disconected the charcoal canister, won't fill.
When I bought the truck, there wasn't a bed on it, so I have nothing to reference to know how the filler neck and vent hose are suppposed to be orientated.
Could some post or link to how those lines are supposed to be routed? I pretty much made it up as I went along.
Old 04-03-2011, 12:16 PM
all4ford94 all4ford94 is offline
all4ford94 is starting off with a positive reputation.
the hose may be pinched somewhere too, if i was you i woud get underneath the truck and check all your lines and your hose that goes from your gas tank to where the gas nozzle goes in. i had the same prob with my old truck and thats what i had done when i replaced the bed in it.
Old 04-03-2011, 12:26 PM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
5-6 mins/gallon is extremely slow, assuming you are not exagerating. I don't think that will be from a vent problem. It could be the fill hose is kinked. It could also be something has become lodged in the fill tube, like the bottle cap from the top of a Techron bottle, for example. See if you can get a siphon hose to go all the way down the throat.
The plastic tube part that penetrates the tank, and connects to the fill hose, is only about 1" diameter.
Old 04-03-2011, 12:59 PM
barthel's Avatar
barthel barthel is offline
barthel has a good reputation on FTE.barthel has a good reputation on FTE.
Definitely a pinch or blockage in the main fill pipe. I had the same problem with my Mustang after I replaced the fuel pump. I set the filler wrong and it twisted.
Old 04-03-2011, 01:13 PM
I have replaced the fill hose with a new hose.
I haven't replaced the vent hose, but I've temporarily spliced in some plastic pieces where it looked linked.
Is the filler neck supposed to point straight down?
Old 04-03-2011, 01:14 PM
Mr-Pipeline's Avatar
Mr-Pipeline Mr-Pipeline is offline
Mr-Pipeline has a good reputation on FTE.Mr-Pipeline has a good reputation on FTE.
Could be someone attempted to steal gas and bent the valve just inside the filler neck? This happened to my uncles jeep.
Old 04-03-2011, 01:18 PM
*looked kinked
Old 04-03-2011, 01:21 PM
I don't think so, because I can get in around 1/5th of gallon before it cuts off the first time. Like Im filling up the filler neck and the gas can't get in the tank. That's what makes ne think it's a venting issue. Like I can't displace the air in the tank.
Old 04-03-2011, 05:36 PM
I guess Ill just have to pull the bed back off.
The vent hose is about the only thing I haven't replaced. I don't think I can get to it with the bed on.
Old 04-03-2011, 07:16 PM
V10ZILLA's Avatar
V10ZILLA V10ZILLA is offline
V10ZILLA is gaining momentum as a positive member of FTE.V10ZILLA is gaining momentum as a positive member of FTE.
There are some TSB for this problem I think. Check the TSB's
I found this under 2009 F250's. It may still be relevent to you. I don't know. But anyway here it is...
http://www.ford-trucks.com/tsb/fullt...p?tsb=09-20-12
Old 04-03-2011, 10:05 PM
wiingnut's Avatar
wiingnut wiingnut is offline
wiingnut is gaining momentum as a positive member of FTE.
I have heard of the problem v10zilla mentioned prior to the 09 models. Definately good idea to check carbon filter.
Old 04-21-2011, 11:06 AM
kip_66 kip_66 is offline
kip_66 is starting off with a positive reputation.
I had been having the same problems with my 2002 Excursion 7.3L, in that I could not
get fuel into it. I have been struggling for months standing at the pump
for 20 minutes at a time trying to put 5 gallons into the tank..
I read every forum on Fuel neck problems I could find.
I even duct taped a garden hose to my shopvac hose in hopes that it was just
a dirty screen, and that maybe by sticking the garden hose down the neck
that the suction would clear the debris
or dislodge or latch onto whatever it was that was stuck in there....
I even thought that maybe a Tree Hugger had maliciously dropped
a golf ball down my fill neck just to teach me a lesson..
While it was a good idea. The shopvac didnt work...
So last night I decided to tear into it....
Taking the fuel neck off was fairly straight forward. 3 Screws and two hose clamps..
I checked the neck very closely and ramed wire through it several times
hoping to knock out any blockage.. There was no blockages.
So I went back under the excursion and took the main fill hose off of the tank.
It was tight but I accomplished it with a 1/4 inch ratchet. Once I had
the main rubber fill tube off. I scootched up inside as far as I possibly could and put a flashlight
on the main fill nipple.. Lo and behold, there was a round piece of cardboard from
the top of one of my Diesel Additives stuck in there... Not sure how or when it happend
but I am thankful it wasnt an expensive fix..
I am sure, that I am not the only one that this has happened too. I put alot of
additives in it over the winter months too keep my fuel from gelling,
and all it took was one screw up.
The repair took me all of about 45 minutes, alot of grunting and wishing I had
a 3rd elbow on my arm.
Getting the metal fill neck off of the rubber fill and vent tubes was the hardest part.
Before I put it back together I sprayed the outside of the neck and inside
of the fill tube and vent tube with lubricant and it popped in easy as pie.
To help keep from doing this again I will be buying single use bottles from now on..
The top came from one of those big bottles that treats 3 or 4 tank fulls.. So apparently
I didntn notice on the 2nd or 3rd time I used it that the cardboard was stuck on top
of the bottle when I pulled the cap off.
I hope this helps someone solve their problems..
In retrospect.. using my air compressor I probly could have put air onto
the little vent at the left side of the fill neck and blown that piece of cardboard out of the
neck.. That would have been awesome! oh well, its fixed now.
Good luck to you all..
Old 04-21-2011, 11:12 AM
1/5th of a gallon is about all your fill neck will hold.. You have
a blockage.. read my other post. I think it will help you..
Old 04-21-2011, 12:03 PM
bpounds's Avatar
2 bit Californian
Nice story, kip-66. Glad it worked out to be something so simple. And I hope the OP has an equally easy fix.
Old 05-06-2011, 05:28 PM
Well, fixed it.
Removed the bed again. No blockages.
Turns out I didn't have the filler neck in the correct orientation. Fills up just fine now.
The last time I put the bed on it really sucked with just two people, trying to lift it over the tires. This time I got creative with a small tractor and ratchet straps.
06 5.4 carbon canister delete? FlAcracker75 Modular V8 (4.6L, 5.4L) 15 12-22-2016 01:34 PM
96 f350 fuel canister empty, tanks full spivf350 1987 - 1996 F150 & Larger F-Series Trucks 4 03-21-2014 01:53 PM
74 fuel filler hose 1974 f100 1973 - 1979 F-100 & Larger F-Series Trucks 10 01-08-2014 12:42 AM
Carbon Canister Replacement FoxNotch 1999 to 2016 Super Duty 3 09-07-2013 09:53 AM
Carbon Canister Help 2005 F250 5.4 JonathanE 1999 to 2016 Super Duty 0 02-26-2012 09:04 PM
Tags
2001, 2006, 99, diesel, explorer, f250, fill, filling, ford, fuel, gas, kia, problem, ranger, sedona, sport, tank, trac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
