Trick My Truck? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Trick My Truck?
Old 04-03-2011, 02:51 AM
HawgDawg's Avatar
HawgDawg HawgDawg is offline
HawgDawg is starting off with a positive reputation.
Trick My Truck?
I just got this '04 F250 about 10 days ago. The truck is VERY low mileage (43,000) and has a lot of life left. I will most likely have it for a long time so I am looking for suggestions on accessories to add or changes to make to the truck that would give it a unique look. I like the looks of the truck for the most part so no big tires or smoke stacks sticking above the cab. I don't have a lot of money to dress it up but would like to consider a few items. I will soon be ordering a soft Tonneau cover, that is a given. If I had the money I would put black rims, black grill guard, and black running boards on it. I think that would look pretty good but I don't have the $ to do all of that right now. The truck will be pulling a 5th wheel camper part time.
Old 04-03-2011, 09:15 AM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
If you are pulling a 5th wheel, just limit your customization to wheels and new stock size tires. Maybe some chrome on the mirrors, grill and door handles, and maybe some new steps. I want to replace my factory steps (think they hang too low) but my wife likes the low step up.
Old 04-03-2011, 09:19 AM
ontariofarmer's Avatar
ontariofarmer ontariofarmer is offline
ontariofarmer is gaining momentum as a positive member of FTE.ontariofarmer is gaining momentum as a positive member of FTE.
Nice looking truck.
As far as dressing it up goes, everyone has their likes and dislikes.
Just do what YOU like......after all......it's YOUR truck.
I'd like to add a couple things to mine as well, but like you, the money is a little tight right now
Old 04-03-2011, 09:43 AM
HawgDawg's Avatar
Yeah farmer, I know that everyone has different likes/dislikes. I was just looking for suggestions because I thought I might get a suggestion I hadn't thought of. Thanks for chiming on.
Old 04-03-2011, 10:01 AM
acf6's Avatar
acf6 acf6 is offline
acf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputation
In my opinion i think you should add some roof clearance lights
Old 04-03-2011, 10:23 AM
Furian's Avatar
Furian Furian is offline
You Keep What You Kill
Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.
I assume that you have the 6.0L diesel engine. I would change all the fluids and filters for a start. Later, I would go with 18" or 20" wheels and 33" tires of your choice. Also, you may want to install Bilstien HD or Rancho RS9000LX shocks for a better ride. Finally, I would add gauges to better monitor the engine and transmission.
Old 04-03-2011, 10:25 AM
HawgDawg's Avatar
@redford, my wife likes the low step too our I would consider replacing them with a higher step.
@acf6, I like the idea of clearance lights. I'm gonna look into that. Any recommendations a far a brand names?
Old 04-03-2011, 10:30 AM
acf6's Avatar
You should do an OEM Ford setup from your dealer or a junkyard, and if you dont like the orange covers you can get smoked or clear covers from recon with amber bulbs. I would probably stay away from their entire cab light setup though, have heard lots of water leak stories about them on here..
Old 04-03-2011, 10:42 AM
Mr-Pipeline's Avatar
Mr-Pipeline Mr-Pipeline is offline
Mr-Pipeline has a good reputation on FTE.Mr-Pipeline has a good reputation on FTE.
How about an F650 lower dash which allows for uplifter switches and gauges that provide useful information e.g. transmission temp.
Old 04-03-2011, 10:47 AM
HawgDawg's Avatar
I should have mentioned that it has the v10 motor. Fluids and filters have been changed. What would bigger tires and rims do to me as far as towing ability? I have a trans temp gauge, what gauges would you add?
I have not heard many good things about recon.
Old 04-03-2011, 10:52 AM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
Since you are talking about cosmetic changes to make on the cheap, I would suggest getting the windows tinted nice and dark (~$300) and getting the stock rims powder coated black (~$300). Then, as money permits, you could get the running boards and grill guard powder coated black to match.
Old 04-03-2011, 11:28 AM
HawgDawg's Avatar
Love the looks of the F650 lower dash, and it's functional.
The window tinting is a definite possibility although I will have to check to see how dark I can go according to state law.
I wonder if I would be money ahead by powder coating my stock rims black or buying black rims and selling my stock rims. Definitely something to think about.
Old 04-03-2011, 12:16 PM
Maybe a 05-07 headlight w/relay upgrade or a full blown 05-07 front end upgrade? The 05-07 headlights w/relays are a must IMHO. The relays provide a full 12+ volts at the headlights instead of the stock voltage of somerwhere around 10.5 running through the switch. You can find more information in my albums.
Old 04-03-2011, 12:56 PM
Hawg......I would stick with OEM wherever possible.
Cab lights are going to be my next job
Old 04-03-2011, 01:10 PM
If it's the factory gauges...it's almost worthless! All of the factory gauges work as a glorified idiot light. Example, the oil pressure will ready normal if you have anymore then aproximately 7 psi. The other gauges work the same. I'm installing autometer gauges to replace all factory dash gauges and adding a trans temp gauge. I'll have pictures within a week or so. You can also consider a scan gauge...these offer most real time readings for much cheaper.
How To: Power Steering Pump Replacement nstueve 1987 - 1996 F150 & Larger F-Series Trucks 80 02-05-2016 01:33 AM
HOLY SCORE, BATMAN!! vntgtrk 1957 - 1960 F100 & Larger F-Series Trucks 49 03-16-2014 06:42 PM
HELP!! I HAVE NO IDEA!!! Wicked Endings 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 03-11-2014 05:55 AM
Looking for 1936 Police Panel Truck w/ Porthole Windows IconDesign29 1947 and Older Ford Trucks 2 11-05-2013 10:44 AM
Cab light upgrade with pics - Recon caprang 1999 to 2016 Super Duty 21 05-09-2012 10:24 PM
Tags
18, 2003, 33, 4x4, bronco, duty, f150, f350, ford, functional, fx4, stock, super, tires, trick, truck, upgrades, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
