lmc parts..... - Ford Truck Enthusiasts Forums
lmc parts.....
Old 04-02-2011, 10:16 PM
traxx808's Avatar
traxx808 traxx808 is offline
traxx808 is starting off with a positive reputation.
lmc parts.....
hey guys i need your advice........i found a new drivers door for a 92-96 p/u truck. i have heard that lmc has there parts made overseas in china. i don't know if that is true or not. has anyone used body replacement parts from lmc and what do you think about the fit and finish of these parts on your truck. the person wants $200 for the door. i think its worth it but, i just want input from anyone that have heard or used parts from this company before i drop 2 bills for this door. i have heard from some people that the fit is not that good and the gap around the door is narrow and wide at some areas. will i be better off getting one from the dealer or is this lmc door just as good as the 1 from the dealer. thanks for the feed back in advance.
Old 04-02-2011, 10:36 PM
Nickk97tml's Avatar
Nickk97tml Nickk97tml is offline
Nickk97tml has a good reputation on FTE.Nickk97tml has a good reputation on FTE.
go lmc!! i purchased body metal from there and i must admit it was pretty thick metal
all the panels for this build was bought from LMC check it out:
1992 Ford F150 Project Fiery Redhead - Four Wheeler Magazine
Old 04-03-2011, 01:14 AM
70torino429's Avatar
70torino429 70torino429 is offline
70torino429 is starting off with a positive reputation.
Have not bought any body parts from there but all the stuff I've bought from them is made in an overseas country. Usually Taiwan. Wasn't overly impressed with the thickness of leaf spring hangers I bought from them.
I'd take LMC over a dealer for a door, but I'd also be poking through the junkyard before either of those two choices. It's only OEM once.
Old 04-03-2011, 01:32 AM
L. Ward's Avatar
L. Ward L. Ward is offline
L. Ward has a good reputation on FTE.L. Ward has a good reputation on FTE.
For the replacement radiator core, I went with LMC, it was cheaper to get the same part from them, including shipping costs, sent from KC to SC than from NPD up in Charlotte O_o. For the doors, fenders, etc, I roamed the local P&P JY and got OEM metal. Case in point, 2 rear crew cab doors with no rust or dings or anything other than missing door panels from the local P&P for my '94 build $60 for the pair. 2 rear crew cab doors from FoMoCo $700 each (list is $900)
Old 04-03-2011, 08:06 AM
Ed Bamba Ed Bamba is offline
Ed Bamba is starting off with a positive reputation.
Not sure what country of origin it was made, but I purchased and installed an accelerator pedal spring from them that lasted only a few thousand miles before it broke. I paid roughly $12 for it including S&H. Since it didn't last as long as I would have liked, I'm looking for another source for the spring. The pedal, as an assembly, cost way more than I am willing to spend. BTW, the original spring lasted over 200K miles and almost 20 years of use.
The part I'm referring to can be seen here: LMC Truck Parts - Page 38 It's item 4 in the top illustration.
Old 04-03-2011, 09:09 AM
USMC0351fordtruckin USMC0351fordtruckin is offline
USMC0351fordtruckin is starting off with a positive reputation.
i would go 2 the junkyard since ford was the best selling truck for the past 30+years thats all i ever really see in there so parts like a door or fender r pretty cheap i can get 1 for like 20-50 up here in PA depending on the yard and the shape its in, but a bed is a different story im driving 6hrs up to NY 2 get a good bed off of a guy i meant on here.... i refused to put OE after market parts "body panels especially" on my truck thats y i would never use LMC or anyone else except for may a gas tank or something minor lots of time the FORD has the same part for just as much but sometimes not... but i believe NPD sell OEM (FORD) doors idk how much but u could check...
Old 04-03-2011, 09:26 AM
hammerhead90's Avatar
hammerhead90 hammerhead90 is offline
hammerhead90 is gaining momentum as a positive member of FTE.hammerhead90 is gaining momentum as a positive member of FTE.
9 times out of 10 the OEM parts are going to be better quality than aftermarket. I would go with the used door.
Old 04-05-2011, 02:05 AM
traxx808's Avatar
thanks for the feed back. i will be looking into everything posted. thanks again.
Old 04-05-2011, 03:21 AM
strokem strokem is offline
strokem is starting off with a positive reputation.
I have ordered many parts from lmc. Never been let down yet. I believe it says in their magazine that their sheet metal parts are made in china. I have never ordered a large body part, like a door, from them. Good luck.
Old 04-05-2011, 11:45 AM
Ohio Ford Farm's Avatar
Ohio Ford Farm Ohio Ford Farm is offline
Ohio Ford Farm is gaining momentum as a positive member of FTE.Ohio Ford Farm is gaining momentum as a positive member of FTE.
have not bought body parts from LMC. I have bought a bunch of other things. Some stuff is pretty hard to find other places... some stuff is way over priced. ... I think they just hate me tho. Every time I order from there they sit on my order for like a week or two before they ship it.
I got my last set of doors off a guy on craigslist. got a set of pretty clean doors for $150 bucks.
Old 04-05-2011, 02:07 PM
IowanStraight6's Avatar
IowanStraight6 IowanStraight6 is offline
IowanStraight6 is starting off with a positive reputation.
im one that calls around and asks where its made if anywhere else but us or canada i dont bye it of course unless if i cant get it anywhere else call me crazy but its what i belive in
Old 04-05-2011, 02:54 PM
RustyGreen's Avatar
RustyGreen RustyGreen is offline
RustyGreen is starting off with a positive reputation.
I just ordered an LMC catalog over the weekend, not that I'm ready to order but I want to look it over before I need to order anything. I was glancing at the online stuff, and I hope I read it wrong but I thought it said they wanted over 40 bucks for an oil dipstick tube!!- I'm thinkin I read it wrong.
But on the sheet metal, MY local P+P... everything is soo roughted out that ordering in would be only option.
Old 04-06-2011, 10:33 PM
traxx808's Avatar
well i got the door for 2 bills today. i went to the local jy to check things out and everything i saw were either dented or rusted. i just hope that this door will be good for fit and finish. the only thing now is that i need to rust proof the door. thanks for the help everyone.
Old 04-06-2011, 11:08 PM
Kapusta's Avatar
Kapusta Kapusta is offline
Kapusta is a name known to allKapusta is a name known to allKapusta is a name known to allKapusta is a name known to allKapusta is a name known to allKapusta is a name known to all
Quote:
You're not crazy. I'd rather help put food on a workers table here than on some guy's table in china.
People in china don't care if we starve.
I used to like LMC's catalogs and often used them for their diagrams if I didn't have any other reference. Most of their stuff is just overpriced crap except the OEM. The OEM is just overpriced.
Old 04-06-2011, 11:24 PM
CWPottenger CWPottenger is offline
CWPottenger is gaining momentum as a positive member of FTE.
http://www.shermanparts.com is also a source for many parts.
LMC body parts any good? shameless 1973 - 1979 F-100 & Larger F-Series Trucks 15 02-22-2014 05:09 PM
Doors 1976 F250 Supercab 23racer 1973 - 1979 F-100 & Larger F-Series Trucks 4 02-17-2014 09:09 PM
LMC TRUCK PARTS AND MIRRORS moparmusclecars 1973 - 1979 F-100 & Larger F-Series Trucks 1 10-02-2011 07:49 AM
LMC vs. NPD - Major Price Difference AstroFab 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 05-28-2011 09:20 PM
question on quality of new body panels DKA-78 1973 - 1979 F-100 & Larger F-Series Trucks 11 11-22-2007 09:27 PM
Tags
58, 9296, catalog, crew, doors, econoline, escape, f350, ford, lmc, mionor, parts, partsford, propane, sale, torino
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
