heater core replacement on 95 F-150 ? - Ford Truck Enthusiasts Forums
Old 04-02-2011, 08:33 AM
crossy crossy is offline
crossy is starting off with a positive reputation.
I'm a basic mechanic with above average amount of tools. can it be done at home without removing entire dash. the truck has A/C. thanx , crossy
Old 04-02-2011, 08:39 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Never had to do it but as I understand it this is what you do, disconnect heater core hoses, pull glovebox, remove bolts from around the cover plate, remove cover plate, remove heater core.
No need to remove dash or anything else.
Old 04-02-2011, 08:58 AM
raptor1971's Avatar
raptor1971 raptor1971 is offline
raptor1971 is starting off with a positive reputation.
What lazy k said. I add make sure the seal is good for the box. I replaced mine last summer and come winter I had no heat. It was blowing out of the box onto the floor. My new heater core did not come with the foam sticky strips, but my friend's new heater core did and he gave them to me since his seal was still good. You can get the sticky foam from the hardware store.
starter issues- 157 T flywheel, old bell housing crossy 1973 - 1979 F-100 & Larger F-Series Trucks 3 07-16-2016 10:13 AM
FUSE for wipers or power source- where is it? crossy 1987 - 1996 F150 & Larger F-Series Trucks 0 12-23-2014 01:28 AM
what size bolts? front shock towers to frame mounting. crossy 1987 - 1996 F150 & Larger F-Series Trucks 0 05-28-2014 01:13 AM
getting headlight assembly out of 93 crossy 1987 - 1996 F150 & Larger F-Series Trucks 6 08-26-2012 10:37 AM
dash pad over glove box crossy 1987 - 1996 F150 & Larger F-Series Trucks 5 06-21-2012 10:29 AM
Tags
1993, 1995, 1996, 302, 350, 95, coil, core, f150, ford, heater, installation, replace, replacement, schematic, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
