junkyard motor, what should i pay?
I once bought a 300 from a private seller for $300, its always a gamble if you haven't heard it run, mine always had a pretty heavy rattle, which I never properly diagnosed until it striped the timing gear, found my lifters were stuck. Turned out to be a pretty good engine, but you never know... if you have to pull it yourself, try to stay under 200, unless you test drive it first, if its already pulled and tested by someone else,3-4 is quite reasonable
Example:
A bare engine block, that is still within spec to be bored and decked for rebuilding is a rebuildable core.
A complete engine with a good crank, heads and block is also a rebuildable core and would obviously cost more than a bare block.
A complete engine with a spun bearing and a cracked head is NOT a complete rebuildable core, as the head is shot and the crank MAY be shot, in this case the only rebuildable component is the block itself. Cost should be the same as a bare rebuildable block.
If buying a core to rebuild, check and see what kind of warranty is offered on the parts. At the minimum it should be a 10 day replacement on the parts to allow time for disassembly and checking to make sure everything is within tolerance and spec for rebuilding. If the supplier is not willing to give a warranty, walk away and look elsewhere as I have seen blocks, heads, and crankshafts that appeared to look good, but failed to be within spec to be rebuilt.
Cores need a rebuild and drop in engines run and won't need a rebuild. Here are a few for you to check out in your area. How many miles does Layla have on her now>????? Keep in mind 300 I6 Core engines are dime a dozen in old beater trucks. you should be able to find a old truck with engine or just a core for $200-$500 really easy! I like the first link below the best unless you want a parts truck... You can use that rebuilt block and turn it into a long block with rotating assembly with head. You'll probably need a seals and gasket kit for $100 and a few things from your engine but it would be the cheapest way to get a zero mile I6 into Layla!
Already rebuilt and needs assembly (good deal!):
300 Ford 6
Rebuildable core:
300 Ford Industrial Engine
ford 300cidw/4spd&transfercase
1985 Ford F-150 4x4
1990 ford f150 parting out
1988 ford bronco ($100?????)
Drop in replacement engine.
1995 F150 4.9L 300 inline six motors
92' E150 van $650.00 OBO parting or all
Keep in mind if you find one that is running and sounds good. Chances are you're not going to have problems rebuilding it and using it as a core. That's why I'll buy a parts truck for $500 or less if i can drive it away or hear it run. You know the engine is good at that point and the rest of the truck can be hauled to the metal recyclers to recoop some $$$$!
300 Ford 6
Rebuildable core:
1985 Ford F-150 4x4
However, you can blow $1500 easily getting your block, machine work, and new parts. I've probably dropped the better part of $2000 on my 351w. Machining $307.61 (no head work), Comp cam and lifters $200ish, oil pump $30, rebuild kit $373.95, timing set $35, plugs-rotor-cap-wires $60, water pump, piston machineing and pressing $120ish.... and this is all without any head work!!!!! That's why I suggested the I6 that already had machining done and new parts in... $425 is stupid cheap for all the machine work and parts if he has them all. Plus he said the head work is done! head work alone can cost $300 pretty easy if you just droped a head off for rebuild and picked it back up. That block may not be EFI though so there may be some differences... I'm not really sure what they would be but there could be a couple...
